COBB Accessport Now Supports 991 Carrera, Carrera S, and Carrera GTS
#436
Basic Sponsor
Major update for those taking advantage of our PDK Tuning option! Existing PDK OTS Maps have been up-revved to v202 and feature a large improvement in shift time. A new COBB Sequential Style PDK OTS Map offers four new features - No Creep, Neutral By Paddle, Inverted Shifter Stalk, and Kickdown Elimination.
For more information, head over to the COBB Blog : https://www.cobbtuning.com/porsche-p...style-pdk-map/
Marshall@COBB
PORSCHE EXPERT GROUP - TIM | GRANT | HJ | ANDREW | JARED
COBBTUNING.COM | LIKE US ON FACEBOOK | SEARCH KNOWLEDGE BASE |CONTACT US
#437
I just installed the new "sequential" PDK tune - love the reverse shifter sense and the elimination of kickdown in manual mode - a must for anyone tracking a PDK car!!!
#439
@COBB Tuning what is a “normal” (if any) timing correction to see running the OTS 91 or 93 map on a 991.1?
Should we be getting 0 correction all of the time? After 5K I am seeing as much as -3 in my logs doing 3rd gear WOT pulls from 2000 rpm to redline.
I see from the tuning notes that the system is very sensitive and to take action at -6. Is this a hard rule? Are there issues with noise from aftermarket exhaust etc causing the knock sensor to pick up false knock?
#440
Basic Sponsor
An aftermarket exhaust could cause some false knock to get picked up but more typically it is caused by a noisy engine bay (loose bolt, rattling mount, etc.). If you have aftermarket headers, it may be causing some minor changes to AFR which the ECU is responding to!
- Andrew@COBB
#441
Do you have any plans to make any adjustments to the PDK shift points in the future? I love my Cobb and the higher shift points, but I also love to drive in sport mode to keep my valves open. But then I'm screaming down the road at 4k rpm at 35 mph because it's just hanging there 🤣
I realize I can just drive around in comfort mode (where the shift points are perfection for my usual drives), but then I can't hear that amazing exhaust sound. I want it all dang it!
#442
I ended up buying my Cobb accessport with off the shelf tunes and a couple custom ones from another Rennlist user. It also comes with the PDK tune.
My question is if the PDK tune is all in one or if it can be a la carte in terms of the features. For example, what if I wanted to keep the kick down feature?
#443
Silly question. Can someone confirm if the latest map has corrected the shifting issues (for the 991.2 3.0L platform) that was reported by other users ? I know that many Pro Tuners have the solution to it but I find it a little unfair to be "forced" to use a Pro Tuner service to resolve something that's causing so many complaints.
