Coolant / Antifreeze - Type for 991
Pentofrost E from Pentosin
Well after all the talk about heaters not working and finding out how the little gizmo works in our coolant bottles, I found my indicator resting on the "MIN" mark.
So what kind of coolant is in our cars? The search begins.
I didn't get any hits on rennlist or other forums that answered my question so I turned to the net and O'reilly auto parts web site popped up and using their search feature is showed that Pentofrost E from Pentosin is the fluid to use. Going a little further searching the Pentosin web site I found the spec sheet referencing the proper Porsche spec number.
My dealer is about an hour away so I ordered a bottle from O'reilly and had it delivered to my local store. I had it in my hands in 2 hours since their warehouse is local.
http://www.pentosin.net/specsheets/Pentofrost_E.pdf
Received 5,388 Likes
Don't use it. Only use the Porsche stuff.
You can top up your coolant level with distilled water. Probably less than 20 ounces needed.
Captain_ (02-22-2021)
HBO does have quite a bit of drama, I think a forum like this is more like PBS.
The car holds over 800 ounces of coolant. 20 ounces of distilled water to bring the OCD bobber into the middle zone is a non issue regarding freeze protection.
Never add tap water to your cars.
In an emergency, grab a bottle of bottled water from a 7-11. I like Fuji because it's shape.
I'd take the Porsche interval and cut in 1/2.
So, for me, in 4 years, that's about 50,000 miles. I'll do it before 60,000 for sure.
For a low mileage garage queen, I'd say about 6 years.
Lease. Follow the book. Just don't buy it at lease termination.
The factory fill level at time of delivery, I believe, is at the MIN mark.
Mine was fully setting on "Min" and it took less then 16oz to put it between the 2 marks.
http://www.porscheownersmanuals.com/...carrera/6/221/
There is no empty mark so it needs to be somewhere in between the 2 marks.
Like the manual says, only fill if you get a warning light.
Mine always seems to be at the min mark after it has sat for a couple of days. Even after I filled it up towards the max mark a few day later, it was back at min. Took it in, but dealer tested and said no leaks. SA said same thing, unless you get a warning light, don't worry about it.
I ordered and used the expensive Porsche stuff.
I'll monitor it a bit and see where it goes.
The car might overflow after heated up and reset it self and end up at the min mark. If that happens I won't top off again.
You could also get a liter from suncoast or pelican parts to have on hand when you order other stuff. As the level goes down, refill at half with distilled water and you have 50/50! Of course I realize I'm a bit old fashioned, but I do live a few hours from the dealer so like to have things on hand.
