Door Rattle When Shutting
Hi Guys,
Apologies if this has been posted before. I just became the proud owner of a new 2016 Sapphire Blue C4 GTS. The car is a dream in every way but I just have one small niggling thing. When shutting the drivers door, there is a very slight rattle from the window which I am guessing is coming from the topmost part of the window. I took it back to the dealer and he said the noise was normal. The passenger door on the other hand closes with a beautifully smooth "thump". The service advisor stated the driver and passenger doors are a different architecture. Now it is not a major shake but I can just feel that it is not as it should be. Or maybe it is normal. These small things drive me nuts :banghead: Thanks in advance for your help.... |
Doesn't sound right and seems like a very lazy answer. Is there another dealer?
Shoot a short video clearly capturing the sound difference between driver and passenger doors, and post up on this forum. Might help us to help you, and perhaps get attention to the problem. As described though doesn't sound right to me....
Both of mine make a "clack" sound rather than a thump. Thought that was normal. Make sure the glass goes up/down slightly when you open and close the door.
Where is the window position when you hear the rattle? If fully closed, does it also happen open. Does it happen if 50% lowered. The idea is to isolate where the sound is originating. Let us know.
my current and former 991 coupes' doors all close(d) with a typically Germanic low pitched , air sealing, solid " frwop "
2 Attachment(s)
Originally Posted by plenum
(Post 12908702)
Originally Posted by mtony
(Post 12908717)
I suppose it is more of a clacking noise now that @mtony mentions it... |
Originally Posted by 991carreradriver
(Post 12908878)
sorry , but your door close sound , most apparent in the first audio file is " ghetto " ....and is NOT acceptable for service dept personnel to lazily say " they all do that " . What they are REALLY saying is that there are several possible adjustments that mechanic can make but he has to be sure they all harmonize or else one creates endless loops of misadjustments by chasing one after another one ...ergo why they are " lazy " to do it because it is warranty and they only get minimum flat rate like seeing an HMO health provider vs a fee for service one and being paid by Porsche for 30 minutes in what might end up being two hours of shop time/ labor the dealer must cover ....
The service dept is a profit center ( " no workie/no payie " ) so when they makes excuses NOT to do something , there is an economic reason from their side ! Bottom line though is this type of rattle should not be heard in any newer car today , IMO , even on a $15k econobox |
agree that is not normal. Any other issues like wind noise, is it properly closed/aligned?
Originally Posted by busta2706
(Post 12909293)
The sound is most obvious with the window all the way up....tried all positions. Thinking about it now, maybe the U-Shaped Hook on the inner door sill receiving the door hook needs lubrication? Just thinking out loud here...
I don't have the rattle on closing but do have it in the driver's side Bose speaker when bass hits. Now before you blame me for being one of those raucous yoots who listen to that damn rock and roll too loud, I have my Bass set at +1 (out of 6) and I almost always listen to old-school jazz (pre-1975). Mostly string-bass, not electric. And at low volume. But still it buzzes. Only on the drivers side. Had it replaced in the summer, it's doing it again. Shift the fader or balance all the way to back or right and it goes away. Guess I'll try again with replacement.
Firstly, thank you all for pitching in...really appreciate it.
Once the door is closed everything is rock solid. No wind noise or any other rattle. Side mirror is perfect as well. Even when closing the door standing outside the car the sound is perfect - a perfect swoop into closing position just like it should be. And therein is the other problem: I am worried that if I hand the car in for them to check thoroughly which will inevitably entail them removing the door panels off a brand new car, this may result in further issues down the line. I am starting to think that the window tinting has something to do with it maybe? |
I don't hear that sound on mine. I would take it to another dealer that cares more about your concerns.
Have you tried resetting the window position memory? While the car is on w/engine off, you roll the window all the way down, release the switch, repress the down switch and hold for 3 seconds, release, roll the window all the way up, release, repress the up switch and hold for 3 seconds.
I had to take my passenger door apart to replace the passenger window switch, I looked up how to do it online and had to buy a plastic trim shim set, but it was actually pretty easy. Just don't forget to disconnect the battery so you don't accidentally set the airbag off. Of course if your car is under warranty, it should be your dealership doing that, since it's their job. |
