Recall Notification
#61
All my driving today was in sport/automatic PDK mode.
Will update after I rack up more miles tomorrow.
The invoice said that I receive the WF86 DME Reprogram.
#62
I saw this on Planet 9 concerning the WF86 DME reprogramming. Doesn't sound like it would have anything to do with the engine stumble issue, especially for manual transmission cars:
I received the following description from Porsche for the WF86 campaign "Due to a software error in the DME control unit, there is a possibility that diagnostic information for the PDK control unit will not be further processed correctly by the DME control unit on the affected vehicles."
Maybe it is a different campaign for Caymans, but seems like it would be a different campaign number if that was the case. Has anyone actually read the text from Porsche describing this DME reprogramming campaign?
#63
It just could have reset everything and once I drive a few more times it will come back .... but we can be hopeful.
#66
My DME and PDK were both reprogrammed. The tech also said there was a DME reprogramming that also effected the instrument cluster, but my car did not need that.
#67
My car is in now for some service and service manager said i need WF86 DME reprogram. 2016 TARGA GTS with PDK.... only 700 miles....SO i am thinking its the same as described by GSIRM3 above
#71
The dealer did the WF86 update this week on my 2015 Carrera S with PDK and 15,000 miles when it was in for replacing a leaking transmission oil cooler. I have never had the stumble issue. I cannot feel any difference in the PDK or engine performance on my 50 mile drive back home. I did notice on the freeway with the auto start button turned on for the coast feature (picks up about 2 mpg) that it only dropped to 950 rpm idle during coast . . . it used to drop to about 850 rpm.
#72
#73
I have a 2015 991 GTS Cab with PDK - 1700 miles 1st Birthday so booked for oil change. Dealer said I need the WF86 reprogramming. I did not ask questions. Getting it updated on Saturday + oil change and I requested the PCM update because it crashed twice. I am on PCM V4.73. I believe V4.76 is the current one - correct?
This is the wording from the Service Confirmation email - not sure why it says Boxster/Cayman. I have a 991!
"Requested Services:
- CUSTOMER REQUESTS UPDATE PCM SOFTWARE
- WF86 - Re-programming DME Control Unit (MY 2013 up to 2016 Boxster / Cayman)
- CUSTOMER REQUESTS OIL CHANGE AND FILTER"
#74
I have a 2015 991 GTS Cab with PDK - 1700 miles 1st Birthday so booked for oil change. Dealer said I need the WF86 reprogramming. I did not ask questions. Getting it updated on Saturday + oil change and I requested the PCM update because it crashed twice. I am on PCM V4.73. I believe V4.76 is the current one - correct? This is the wording from the Service Confirmation email - not sure why it says Boxster/Cayman. I have a 991! "Requested Services: - CUSTOMER REQUESTS UPDATE PCM SOFTWARE - WF86 - Re-programming DME Control Unit (MY 2013 up to 2016 Boxster / Cayman) - CUSTOMER REQUESTS OIL CHANGE AND FILTER"
#75
Let's see!
