Bilstein / Spring Dealer Install
I'm considering installing a set of either B16s or Techart springs... Does anyone have experience with having a dealer install, and what the install cost would be at dealer rates? In theory, I assume the B16s would be less total time, but I'm guessing it doesn't work that way...
I'd be interested in hearing the answer to this ...
my guess is that it would be a wash rate-wise, it might be a bit simpler to install the B16's since it would not require spring compressors but at the end of the day its 4 corners + alignment.
As far as price goes, TechARTs are around $600, B16 around $3k ... KW H.A.S circa $1500
I have done a spring upgrade on every car I've owned but only used a dealer once. My logic is that I wanted a Porsche focused shop that setup race/track cars because I had more confidence that the setup would be right. The last time I did an upgrade, putting Techart on my 991, I had the dealer do it. Big mistake. They charged me about $1,200 which is the most I have ever paid. Once side of the car sat lower than the other and they had to re-do it, and I'm still not convinced it's right.
The point is I would only use the dealer if I had no other options. If you can I'd look for a shop that works on Porsche's with a preference for ones that setup cars for track days.
Good luck.
Good luck.
Good luck.
Good luck.
alignments (esp w/the coilovers)
I would have them done at the Exchange (Chicago) if at a dealer, and they do aftermarket no problem... I'd prefer to have the dealer do it, as that's just my preference since they do all other work, but if the price difference was dramatic compared to an aftermarket shop (perfect power, fall-line, etc) than I'd just take it there...
I also wasn't sure if there was a difference in springs vs coilover install, as I would imagine coilover is much quicker as it's a more clean swap... Understanding the difference in part pricing, but I'm not et decided on which to do, as the ability to raise it in the winter would be nice (coilovers), but 600 is also a lot nicer than 3000...
