Driver Side Wind Whistling with window up
Old 04-07-2016, 11:16 PM
sstreime
sstreime's Avatar
I have the same issue and am thinking it is the mirror housing that is whistling but am not sure. Trying to open and reclose the window does not seem to fix the issue.
Old 05-05-2016, 07:12 PM
911Enthusiast
911Enthusiast's Avatar
Originally Posted by 911Enthusiast
Exactly the same issue started on my 1.5 months old '15 911 GTS. High-pitched sound from driver side window starts @ around 65mph. Becomes really becomes irritating @ 85mph.
Took it to local dealer. At first test-drive w/ a tech, they declined there being an issue. On second test-drive w/ a different tech, they acknowledged the problem. But, weren't able to identify a source.
So, I'll bring it back to dealer in a few weeks for them to check a couple of things like:
1. seal @ mirror and door intersection
2. adjust window tilt angle + height
keep y'all posted...
Would love to see those w/ this problem get a resolution.
So after 2 visits to the dealer including re-fitting door panel the problem persists. At least now instead of denying the problem, they seem to be making an effort to find and fix the root cause.
Old 05-05-2016, 08:12 PM
CDH911C2S
CDH911C2S's Avatar
On a BMW I owned I had the same issue.
It ended up being a missing jack pad ---check if all jack pads are place.
Cheers
Old 05-05-2016, 09:01 PM
mtony
mtony's Avatar
Deleted
Old 05-05-2016, 09:03 PM
mtony
mtony's Avatar
Happens commonly with BMWs that have the hard plastic jack pads missing, but I don't think the 991s have those.
Old 05-05-2016, 09:04 PM
Pmorritt
Pmorritt's Avatar
Back in 1993 I bought a Mazda RX3R. Wow what a car. I had a whistling that sounded like a bee. It was the first year of that model and dealer was great to find entry of wind. It took a while but it was the seal around the windshield. Try this. Tape the window, windshield all around. Drive it a bit see it if the noise is gone. Now, start removing a section at a time. Drive it. When you have the noise again, you have identified the area that needs to be fixed. Voila!
Old 10-02-2017, 02:09 AM
kfz03110
6th Gear
kfz03110's Avatar
My 991S has wind whistling too. Yes it's the mirror with clear film on it! I taped the mirror roughly with a scotch tape, the whistling went away! I will call my clear film installer to reinstall the mirror part with a different cut film. Thanks a lot to Polusky!
Old 10-02-2017, 10:50 AM
Speed2000
Speed2000's Avatar
If the film hangs over the edge between the painted part and the black plastic part, it will whistle.
Old 04-27-2018, 01:33 AM
vodkag
vodkag's Avatar
Wow i am having the same issue after xpel on mirror. Gotta try the fix
thanks!
Old 03-25-2020, 08:07 PM
Bulldawgfan1000
Bulldawgfan1000's Avatar
I am having the same whistle above 70mph on driver side. The pitch of the noise changes when the inside of rear quarter window is pressed outwards, leading me to believe it is a rear quarter window issue. No PPF is installed on my carrera. Jim Ellis Perimeter tech located the issue and said he would fix it, but a few days later the service advisor called back and said it was normal. I was not happy, considering the car is under warranty and the whistle is quite annoying. Planning to try Hennessy soon, hoping they will fix and also not cause any other rattles if they have to remove trim/ window to re seal it.
Old 03-25-2020, 08:31 PM
Dewinator
Dewinator's Avatar
Does it still do it if you pause on position 1 for a second before turning the ignition on when you start the car?
Old 03-25-2020, 08:40 PM
Bulldawgfan1000
Yes I have tried that, I also tried resetting the window position sensors following the steps but with no luck. The service advisor said: “these are not quiet cars” which I would agree accept he knows as well as I do that this is not normal for all other 911 coupes. If they are unable to fix I am planning on trying the black mill wind deflectors that help with buffeting with Windows down, but I am thinking maybe they would change the air flow enough to also fix the whistling. I love the car either way though, I just turn up the radio or let down the windows slightly and enjoy the smoothness of the suspension and the power band of these turbo charged 3.0L flat sixes. I came from a 987.1 Cayman which was cool for its own reasons but this 911 is a huge step up for sure!
Old 03-26-2020, 01:51 PM
grendelrt
grendelrt's Avatar
I have deflectors and have been working through this issue as well. I tried tape on my side view mirror, resetting the window, and taping the deflector to no avail so far.
Old 03-26-2020, 03:22 PM
Bulldawgfan1000
The aftermarket wind deflectors did not help? I will update the forum when I am able to take it back to the dealer. This seems to be a common issue Because the rear quarter window is not held in as tightly as you would think according to others here that have taken it out.
Old 03-29-2020, 06:31 PM
DanQ
DanQ's Avatar
I didn't see this mentioned before in this old thread, but the old school way to check for window seal leaks is to close a dollar bill between the glass and the seal. If you can easily pull the bill out with the door closed you need a new weatherstrip or the door glass adjusted. If the bill is trapped and hard to pull out the wind can't get in to make noise. Slide it over the length of the weatherstrip.
Quick Reply: Driver Side Wind Whistling with window up
