Cleaning bird droppings from convertible top?
Did a search but can't find a good answer: is there a quick way to detail the top (targa/cab) to remove bird crap? Can I use a quik detailer solution? I don't want to order another product such as the convertible top cleaner if I can help it for now.
Received 5,388 Likes
Distilled water and soft brush.
How old is top?
How old is dropping?
Buy RaggTopp cleaner and protectant from Detailers Domaine.
How old is top?
Don't use any soap. Try water first. Certainly no detailer spray wax.
I suspect you might need to do the RaggTopp kit. Yours will be easy because the Targa top is pretty small.
Update this post. I'll walk you through the RaggTopp if we need to go that route.
Next time, wash the bird droppings as soon as discovered. Even if you have to stop and by a bottle of Fuji water and a soft toothbrush.
I used to keep a spray bottle of distilled water in the frunk for bug and bird droppings. But I've mellowed over the years and obseese less. It's not easy being me.
