Installing 911 emblem on rear of car
Old 11-04-2014, 06:45 PM
Jerry991
Jerry991's Avatar
Default Installing 911 emblem on rear of car
I removed the 911 Carrera emblems on the back of my car and bought the larger 911 emblem which is offered by the factory and am looking for suggestions on how to install it so it looks correct.
Old 11-04-2014, 07:03 PM
Zohan
Zohan's Avatar
Look at Money's post.... And good luck
Old 11-04-2014, 11:11 PM
ruhlich
ruhlich's Avatar
I did the same. The "911" comes as three separate numbers on a rectangular backing.
With a sharp hobby knife, cut around each number and remove. Now, you have a template on a rectangular sheet. Position the sheet and hold it in place with masking tape. Step back and observe this template for correct placement. Adjust as necessary.
Now remove the backing from each number and place it in the respective cutout of the template. Remove template.
Add talent to your resume'.
Old 11-05-2014, 08:37 AM
Hothonda
Hothonda's Avatar
If only it was this easy ↓↓↓ for the rest of us....go to 4:25 - essentially what ruhlich ↑↑↑ recommends.
Old 11-06-2014, 08:30 AM
Jerry991
Jerry991's Avatar
I guess I am lucky that there is no shadow from the emblems I removed but I am still looking for ideas on how to put on the 911
Old 11-06-2014, 08:45 AM
Porsche_nuts
Porsche_nuts's Avatar
Received 1,115 Likes on 665 Posts
Putt them vertically instead of horizontally. That would be different.
Old 11-06-2014, 04:28 PM
Money2536
Money2536's Avatar
Palm hitting face on this... It's easy to put a badge on when there is one on the car already. Just tape around it and then put the new badge in place. If the car is badgeless, that's another story. I gave up after few attempts. The curvature of the rear bumper made my brain nearly explode.
Old 11-06-2014, 05:09 PM
drcollie
drcollie's Avatar
Received 3,864 Likes on 1,352 Posts
Its not that hard, be creative! I had just '911' on the back of my car and removed it, because its not a 911, its a "911 S" and there IS a difference! LOL..... plus I have too much time on my hands....
So, I ordered "Carrera" and "S", then fiddled around with them on my desk, the whole key is to get the straight on the horizontal, and you'll never do that just eyeballing it, you will have to cut a template. So I took my "Carrera" and "S" and with a razor blade cut away an edge of the backing, then made a template. This photo shows it:
And here is your first template when done:
Next, you have to make a REVERSE of the template you just made (above) and that's what this looks like. Note that you don't have to do every character, just enough to give you alignment. This will be my install template that I worked out on graph paper. I will take this to the car and tape it down, checking the vertical and horizontal alignment about a dozen times:
Then, when ready to apply the emblems, peel off the back and align them to the template, like this:
That's all you have to do....
Duane
Old 11-07-2014, 09:22 AM
Zohan
Zohan's Avatar
I away for a few month and Money goes all out.
Well done, GT3 and M3 are per perfect complement of sports cars to each other.
I like your style
Old 11-07-2014, 09:39 AM
Money2536
Money2536's Avatar
I like your style
I aim to please. Notice how I left the badge on the GT3.
Old 11-07-2014, 09:52 AM
Zohan
Zohan's Avatar
I too fight the urge to fix what isn't broken
Old 11-07-2014, 11:04 AM
drcollie
drcollie's Avatar
And here is the finished product, installed with my template in less than 5 minutes last night. Prep the area with alcohol - center on the existing 'P O R S C H E' ( The middle of the "S" is exactly centered across the tail lights), get your horizontal alignment straight, tape the template on when you are sure of your alignment and press 'em on.
Old 11-07-2014, 05:24 PM
RADManZulu
RADManZulu's Avatar
What exactly did you order for the larger emblem and did you do it through the dealer? I am thinking of doing this with my 4S (ie putting the larger Carrera 4S on) and getting rid of the PORSCHE emblem.
Old 11-07-2014, 06:09 PM
drcollie
drcollie's Avatar
The "Carrera" is a 991 part # 991 559 237 01 , the "S" is larger and a 986/987 part # 986 559 243 01
The "S" is bigger and bolder on the 986 part than the current 991 "S"...Good catch!
Old 11-08-2014, 04:00 PM
Larry Cable
Larry Cable's Avatar
Received 3,419 Likes on 2,235 Posts
Ideally I'd recommend finding a friendly RLer that has the "911" trim on their car and creating a template from that, that way you will get the centering and spacing like factory.
you might also find a Porsche approved body shop, they may have such templates already
Quick Reply: Installing 911 emblem on rear of car
