Euro springs for 991S?
Do OEM, Euro-spec springs exist for the 991S with Sport PASM? I was at the track earlier in the week and saw a new Cayman S with a perfect track stance. It was clearly lower than stock--not slammed Civic low, but GT3 Cup car low. I asked the owner if he had put on coilovers, and he said he just had the lower, Euro-spec springs installed, which allowed him to maintain PASM functionality. Does such an option exist for the 991S with Sport PASM?
I think the fastest way to figure this out is to check PET to see if there are different p/n's for RoW vs.
N.A cars...
this was certainly the case with earlier models M030 RoW & N.A springs.
N.A cars...
the info is in PET but decoding it is the hard part
note that there might also be a different shock and PASM controller
http://www.porsche911.lt/files/991/E_991_KATALOG.pdf
My informal research regarding lowering my own non-PASM Carrera found PASM springs are -10mm, SPASM another -10mm, and various aftermarket springs another -10mm which is about the same as GT3 height. No "euro spec" shorter sport spring for the 911 AFAIK.
