Shark Werks 991 Exhaust Released (with video)
Looking forward to it, thanks.
Alex/Dan,
Any updates on the dyno results for the side muffler bypass? It appears the bumper needs to come off for this modification, based on the first photo. Is that right? Thanks for any further info.
http://sharkwerks.com/porsche/991-ca...s-exhaust.html
It's pretty simple and does NOT require any bumper removal. But it is aggressive/loud and not for the feint hearted!
Just a final update to let you know that we installed our first production unit last week on a 3.4L local car. This exhaust replaces just the center muffler with our CNC mandrel bent tubing and OEM-sized tubing for maximum flow with minimal side effects. The simple system reduces weight on the rear of the car and gives a 50-state emissions compliant option for those looking to get a bit more grunt without check engine lights or problems.
The stock exhaust is removed and weighed:
And the Shark Werks pipe:
A savings of almost 8 lbs, right where you want it most.
And a few minutes later our pipe is installed:
More information about this exhaust is available here.
Made a new video of a 3.8 c2s w/ PSE + Sharkwerks bypass. I included a "cold start" sound bite as well, and IMO it is not as loud as I expected which is good. The overall sound is basically the same as PSE just louder. Props to Sharkwerks for making a quality product with absolutley no fitment issues, direct bolt in / plug and play installation.
Oh Damn now I will need one of these too... what with the new wheels and Bilsteins Alex is going to clean me out!
Just to throw it out there - I have a set of Sharkwerks bypass pipes for a 3.8L S - plus the 3.8L center muffler - if someone is looking to put this type of set up on a base 3.4L car. Bolts right on!
That's awesome. I really appreciate the "chill mode" part of the video that is often neglected. I always wonder what it sounds like at idle.
About how many hours would this take a dealer to install?
We're the side delete pipes ever dynoed?
It depends how they are installed. I did mine myself with a floor jack and only taking off the rear wheels. I'd say it took me 45mn Max, thanks to the DIY thread I read before hand. The dealer might remove the rear bumper which would be easier but not necessary.
