991s will aftermarket headers give me this much gains??
Old 09-19-2013, 02:34 PM
  #31
Team Plutonium
Team Plutonium's Avatar
Originally Posted by Chris@Fabspeed
also for anyone reading this thread that WANTS headers, but can't justify the cost, we have a set of dyno time only developement headers that produced the gains in the above dyno chart. We are selling them for a discounted price of $1600 as they are not new. They still come with our industry best 2 year warranty on the HJS sport cats.
Any ideas about my codes/CEL? I attached the photo of the diagnostic screen...
Old 09-20-2013, 10:42 AM
  #32
Team Plutonium
Originally Posted by Team Plutonium
Hi Chris,
The CEL showed up after about 3-4 cycles, approximately 10 days after the install (I was traveling and didn't drive it much after the install).
I drove yesterday and after the warm-up phase I got the CEL. Attached is a screen shot of the codes we pulled yesterday. Thanks!
Bump...
Old 09-20-2013, 11:58 AM
  #33
exponential
exponential's Avatar
Well, the Fabspeed headers come with 200 cell high flow cats - so that alone will give you a small power bump.
Why don't look for long tube header with 200 cell high flow cat?
Old 09-20-2013, 12:19 PM
  #34
Team Plutonium
Well, I already have the Fabspeed ones for starters, and I'm happy with the quality. I'm also not convinced that long tube headers will give me more power with this particular engine. And, I don;t think anyone makes them and offers them unless I want to have them custom built by b|b|i. In any case, these high flow cats give me a CEL, so I need to figure out first why that is...
Old 09-20-2013, 10:27 PM
  #35
exponential
I understand that you already bought the header. But since you asked if anyone made the longer tube. Here it is :
http://www.cargraphicts.com/index.php?id=141356&L=1
They also come with 200 cell cats and their cats are BIG (5" diameter) which surely give better flow and longer service life.
Old 09-20-2013, 11:02 PM
  #36
Team Plutonium
They are pretty cool.
Old 09-20-2013, 11:05 PM
  #37
exponential
This is very basic information that is incorrect. If we are talking about old engines, with fixed cam timing, non variable plenums, ect. then yes usually the shorter primary lengths will give greater gains on the top end.
With these new high compression/direct injection cars and all of the technology designed to give nice, broad, flat torque curves, exhaust backpressure has more of an effect on the powerband.
Here is an updated dyno chart for our 991 Sport Headers - the one on the website is incorrect.
You may call "basic information" but I call it "Basic Fact".
Looking at your own dyno chart, torque curve between 3500 - 4500 RPM is dropping. That's where the longer tube headers can help to gain more torque in these RPM range. In fact for street use, we use medium RPM range all the time. So it is more useful to promote torque in this area than try to promote power at top end RPM (by using shorter tube header than OEM) while the OEM cam is still in place so peak HP will not move to higher RPM anyway.
Old 09-23-2013, 10:56 AM
  #38
Chris@Fabspeed
Former Vendor
Chris@Fabspeed's Avatar
Our curve follows the factory curve pretty well throughout the entire powerband, just elevated, which is not a bad thing at all considering the solid power gains.
Regarding where to promote the power, that is up to the purchaser where he wants the gains to occur, but in our case there are zero losses and significant gains, even down low, with our sport headers, across the entire torque curve.
Old 09-23-2013, 10:57 AM
  #39
Chris@Fabspeed
Former Vendor
Those codes point to cat efficiency - I wonder if any header bolts are loose? Did you use the factory metal gasket when installing?
Old 09-25-2013, 10:45 AM
  #40
Team Plutonium
I double check with the tech... I believe he used the ones that came with the headers. I'll check it out. Thanks, Chris!
Old 09-25-2013, 12:06 PM
  #41
Chris@Fabspeed
Former Vendor
If he did, I would swap back to the factory MLS gaskets and see if the code persists. It should not as like I said earlier, these are Euro Level 5 emissions capable cats.
Old 09-25-2013, 01:03 PM
  #42
Team Plutonium
Thanks! I'll swap the gaskets to the stock ones, and see if that will do the trick. Thanks again, Chris.
Old 09-29-2013, 01:41 PM
  #43
Team Plutonium
Switched out the fabspeed gaskets to the OEM ones, double checked all the torque specs, codes came back - both banks. Tech pointed out if the gaskets were faulty (or a leak) the primary sensor would have given me a code, and not the secondary. In any case, looks like my cats are bad for whatever odd reason. I'll order 02 sensor spacers and hope this will do the trick otherwise it is back to stock.
Old 10-07-2013, 11:37 AM
  #44
Chris@Fabspeed
Former Vendor
The reason I say this is basic information is because I have a lot of experience dyno'ing the Porsche DFI engines and trying different header designs. Below is a chart of a 9A1 engined race car - engine is stock internally, so stock camshafts, compression ratio, heads, ect. Car is tuned for 100 octane unleaded with forced ignition timing (less safeguards than factory programming - better for comparisons because small changes in ECT or IAT will not change ignition timing).
The long tube are the green lines and produced a small bump in torque from 3700-4000, but produced less torque above this. The curves were very similar though.
Old 10-07-2013, 01:26 PM
  #45
Bacura
Bacura's Avatar
I've given up on all aftermarket stuff. No one has the ability to test their stuff like Porsche itself. Why would Porsche use these mods if they were better. Porsches are incredibly well engineered and with all the computers there is no way any aftermarket company is touching my car. I'm going on to my forth 911 and I've tried many mods including autothority chips/RUF parts/pulling the converters with straight pipes/lowering/quaife differentials etc etc. IMHO the only thing thats worth the effort are maybe wheels and tires. You get nothing back for aftermarket changes and possibly even loose money. Any reliability issues i've had have always been related aftermarket stuff. Do what you wish but I'll only put Porsche parts on my Porsche. Especially so with the new ones.
Quick Reply: 991s will aftermarket headers give me this much gains??
