Rennlist - Porsche Discussion Forums (https://rennlist.com/forums/)
-   991 (https://rennlist.com/forums/991-221/)
-   -   305's on the rear of the CS-performance improvement? (https://rennlist.com/forums/991/745198-305s-on-the-rear-of-the-cs-performance-improvement.html)
LonnieR Mar 12, 2013 03:36 PM
Since they use the same wheel for the C4S for the rear, I was wondering if the 305's that are used on the C4S would add to the performance of the CS. Anyone put 305's on the rear of their 991 CS?
STALKER99 Mar 12, 2013 04:19 PM
C4S uses different rear offset, so not exactly same rear wheel.
John 996 TT Cab Mar 12, 2013 04:32 PM
The Sport Techno wheel on a C2S uses 305's. The wheels are actually 1/2" wider than the other wheel options.
chuck911 Mar 12, 2013 05:24 PM
Both sizes will fit and work just fine on all the models and wheels offered. Feel free to dig up the post a few months back where I said this was the case, as well as the following post where the late great Gary Sims agreed. People seem to have some idea that the tire sizes Porsche chooses to fit are due to some exact science or clearance requirement when in fact its simply a case of a given rim width being able to accomodate a range of tire sizes that will all work just fine. Within that given range there are probably some measurable variations but as Gary pointed out nobody'll ever notice because the difference in width is only about 2%. As easy as it is to change tire performance with just a few psi more or less it should be easy enough to understand why this would be the case.
So why would Porsche fit the wider tires to the 4S but not the 2wd 991's? Well, even though the performance difference is nil the appearance difference is not. The reason is because of wheel well to tire spacing. Let's say your car is set up to where you can fit two fingers between a tire and the fender with the narrower tire size. So you mount the wider 305's. The 305's are only 1cm wider than the 295's, a measly few percent that won't affect handling or performance. But they stick out 5mm wider to the side, which is TWENTY-FIVE percent of the fender clearance. Nobody will ever notice 2%. Everybody can see 25%. They do it for the look.
chuckbdc Mar 12, 2013 06:29 PM
All 20 in rear wheels with 305s on the 4 wd 991s have a different offset ( and are more concave) than the real wheels (Sport Techno) that are optional on the 2wd cars- or the other 20 in that come with 295s. They will fit either car. The effect is like having 5 mm spacers, but without the spacers. I can personally confirm that the wheels do cause double takes and envy, due to the deep dish look.
chuck911 Mar 13, 2013 03:06 AM
Now THAT is interesting! Wonder if Porsche Exclusive can help you order the wider offset wheels on a 2wd car?
© 2026 MH Sub I, LLC dba Internet Brands
