Resetting service light
#31
#32
I bought mine on Amazon, from German Audio Tech
https://www.amazon.com/gp/product/B0...A32ZV9NIXTIMAF
#33
Just reset the Intermediate Service on my 2013 C4 with a iCarsoft PORII from Amazon. The first time in my 71 years I ever did anything electronically to a vehicle. Piece of cake!
#34
You can get the POR-II kit here
http://www.diagnostic-world.com/page...5&p=111381.cfm
We just done this ourselves and made a video showing how easy it is to do it with this kit
#35
I purchased one and eventually was able to reset the oil service light.
The manual, however, is horrible. It took me a lot of time searching videos and write ups to get the device updated -- they could make so much easier. Then, my version's software and sequencing was different from the video above (which is the one I found most helpful). Honestly, it made me a bit nervous putzing around with the car's electronics/programming.
D
D
#40
Does anyone know the difference between the "Standard" and "Bundle" iCarsoft i960 POR II?
https://www.amazon.com/dp/B011DKBXBK...oding=UTF8&me=
I wish someone would make a video with narration showing all its capabilities (Diagnostic World?). But thanks for this one, as the instructions that come neatly bound with the package, I found near worthless. I too was concerned I would hit the wrong button and do damage.
ChuckJ
#41
this is weird. My X431R works great for resetting the service and oil change on my 2015 Cayenne Diesel, but even though it says it reset the 2013 C2S when I went through the motions, it does not appear to work on it. Seems like it should work on the older car. Also, after a year, I finally got around to programming the garage door opener though!
#42
I wanted to verify that the Durametric tool worked for me to reset the service intervals on a 2015 991.1 GT3. I did have to upgrade to the latest version 6.5.5.9( from July 2018). With respect to the car, I had no CEL type messages but I did have a "Service Now" that finally hit based on the oil change date. It was slowly counting down from 20 days or so and it finally expired.
I changed the oil/filter myself. When I tried originally, the Durametric tool did not work so I checked the website with the version info:
http://www.durametric.com/versionhistory.aspx
I realized that I needed to upgrade since I was running 6.5.4.8(from September 2017). It also seemed like they had fixed a bunch of stuff for the 991 in the newer code.
Once I upgraded and logged into the car, it was a slightly different with the new software since it now asked me to chose if the car had PDK and there was also a choice for Sport Chrono. The software upgrade did the trick and I was able to reset the service intervals. It did not ask me for a date like some of the other tools I have seen online but it took the install month and just used that to set the future expire date.
#43
