Rennlist - Porsche Discussion Forums (https://rennlist.com/forums/)
-   991 (https://rennlist.com/forums/991-221/)
-   -   Auto start/stop playing up? (https://rennlist.com/forums/991/713406-auto-start-stop-playing-up.html)
Betternotbigger 08-24-2012 09:28 AM
I'm not sure if this is usual but my Auto start/stop works fine until I hit the motorway/freeway but then, once the car has done some fast miles, it shows as deactivated every time I come to a halt in traffic . Anyone else experiencing this?
Please no comments from those who can't see the point in the feature. It saves fuel and and cuts down on noise and that can't be a bad thing. I like it. But I'm not sure it's working properly. Will take mine to dealer if no one else having the same experience.
Thanks guys.
fbroen 08-24-2012 09:34 AM
This may not be very helpful, but mine shows deactivated sometimes if AC demand high, or engine is cold and just started to heat up. Would yours temorarily overrule to cool down?
Betternotbigger 08-24-2012 10:46 AM
It says as much in the drivers' manual, so I guess I'll try switching AC off and see if the same behaviour persists. But I'm in the UK where it never gets very hot, though the AC has to work hard to dry the air!!
sfo 08-24-2012 10:48 AM
after a hard drive, the car/engine/battery needs time to get back to 'normal', hence auto start/stop disengages.
I would say it's nothing unusual .. it's happened to me on my 981S
aamersa 08-24-2012 10:57 AM
Thanks guys.
This is normal. There are too may factors in play for one to to second guess if it should engage or not. If it works at least some times it means that feature is working. If it was not working you would get an error mesg of some sort. There are just to many variables that impact whether it should engage or not. It's like it has a mind of its own but in reality it is following instructions in its programming.
mjsporsche 08-25-2012 09:47 AM
I have this feature in my new BMW 535. Most of the time, it does not bother me and I always have the option to turn it off. Last night I was in NYC traffic and auto start must have activated 20+ times with the 30 minutes of heavy traffic. I think there will be a new starter in the future.
Romantic911 08-25-2012 06:28 PM
Battery charge status play the big role
Betternotbigger 08-26-2012 05:32 AM
Of course. But the battery will be at its lowest state of charge in the early minutes of use and then at it's highest after the rapid highway miles. My stop/start reflects the opposite.
sfo 08-26-2012 05:36 AM
look at the Voltage on the battery .. it mostly gets charged on deceleration.
peewee72 08-26-2012 07:48 AM
From what I have experienced thus far (took delivery 2 days ago), the stop/start will not function if the air-conditioning is on. Apart from that, 95% of the time it will come on but i have also noticed that sometimes when you are stuck in traffic the function will discontinue if it means you are coming to a halt repeatedly.
rijowysock 08-26-2012 10:32 PM
it's smarter that we are.. mine would do that at weird times but after a while it always did the same so it must know what it's doing.
© 2019 MH Sub I, LLC dba Internet Brands
