AuxIN & USB Plugs?
AuxIN & USB Plugs?
Does anybody know that if the AUXIN plug in the passenger glove compartment is standard without the PCM NAV option?
I know that the USB is only provided if you order the PCM NAV system. However, do you have to order PCM NAV to have the AUXIN plug?
_______________________________
12 991C2S (April-factory delivery)
08 997C2S
10 550i GT
05 Discovery 3
08 997C2S
10 550i GT
05 Discovery 3
in the 958 cayenne, the USB slot is only for nav models... non nav only have the 3mm miniplug..
i would think it would be the same for the 991, if ordered w/o nav you do not get USB and also the PCM doesnt read DVD's (instead of PCM its CDR-31 i assume)
