991 Maintenance Quirks!
Let's get a new 991 maintenance/driving quirks thread going.
I'll go first - During oil change with 991 on a lift, 7.3-7.5 quarts empty however if you use ramps on rear only, 8.5 will drain. |
Originally Posted by ericmeds
(Post 16641498)
I like the ramp trick, nice to drain a bit more oil that way.
I've also learned to use a weight scale to know exactly how much oil I drained and subsequently add. I did this last week and nailed my fill within 200 mL (oil gauge reads exactly where it did before the change). |
Using Quick Jack which raises the car symmetrically, 991.2 C4 GTS drained just about 8.5 quarts after about 45 min.
To change the battery you are forced to drop a bolt into the abyss by an extremely awkward placement on the firewall.
Originally Posted by Jack F
(Post 16642690)
At least on my car, attempting to extract/install the oil filter cannister cover with filter is accompanied by a greater than average amount of swearing as I try to negotiate the virtually nil clearance afforded by the intake runners. I sweartagod my car must be different somehow than all the guys who leisurely remove their oil filter housing cover in like their Dinner Jackets or whatever. :)
https://cimg8.ibsrv.net/gimg/rennlis...859d71bb5.jpeg |
An oddity is having to remove the wheel or turn it and remove the fenderliner in case your battery is completely dead to access the emergency frunk release if you are not successful powering the switch from the fusebox...especially considering the wheel lock is usually in the frunk.
Originally Posted by Rich_Jenkins
(Post 16643717)
Originally Posted by polobai
(Post 16643728)
I remember when you posted this a few months back-after removing my bumper and the air inlet and reinstalling on my car, I am almost positive that your air inlet is not reinstalled properly and that is what is causing the clearance issue on your car.
Car is "stock" and (so far as I know) dealer maintained, prior to me. For sure the bumper cover was off last July when they performed a service that required dropping the tank to fix a fault with a tank vent sensor. Otherwise, no other work. I've stared at the drawings for the install / assembly of that intake runner on the various documentation I have, and it has led me to conclude there is no physical way it can be installed correctly (not allowing for Murphy of course!). But obviously one wonders...I'm pondering a buzz over to my dealer at some point and talk to one of the techs about this. |
Originally Posted by Bud Taylor
(Post 16643643)
The worst for me: having to dismantle the rear of the car to change out air filters.
Originally Posted by Duke I
(Post 16643767)
or when the dealer breaks your bumper and covers it up with tape - making it difficult to remove/install due to it being thicker and sticky from the adhesive :banghead:
https://cimg1.ibsrv.net/gimg/rennlis...849619d8c.jpeg
Originally Posted by koala
(Post 16643906)
I suck at getting the bumper to line up with the rear fenders - almost always bulges out a bit near the wheel arches. There must be some trick to it that I haven't discovered as of yet!
(Post 16644232)
