New Member Looking for Advice on Bad PDK
Thanks for all the replies. Very helpful! I bought the car privately, so no warranty or CPO. I'll try to take a photo but it is tight up in there. It seems to be leaking near the fill plug where the two metal lines enter the casing. It only leaks while driving, not just when sitting. It might be worth a shot at a goodwill repair. I did not know they did that. Thank you for suggesting that I try that first. I won't drive it anymore because I have no idea what percentage of oil has been lost.
I originally found oil on the under tray below the PDK housing so I starting looking for the leak. I cleaned and de-greased the area then drove it to see where it was coming from. I pointed it out to the mechanics and they later conceded I was right after dismissing my suggestion.originally. Apparently there are O-rings there that can fail. In order to repair it they replace those two return lines. So I assume it can happen again. I'm just glad I caught it before it ran dry and failed completely, which it probably would have done on the first track day.
B Russ (03-12-2020)
LOL, everything seems steep with these cars! In fairness though, I'm sure a lot of stuff has to get moved. I can barely fit my hand in there. Then they have to replace the PDK filter and put in new oil. I'm sure the parts are less than the labor for this job. Heck, my dealer charges $195 for an oil change. I can do that myself, of course.
Received 3,460 Likes
Texas Porsche (03-12-2020)
Have you contacted the dealer? You should have at least a 30-day warranty, unless you waived your right to it: https://www.nolo.com/legal-encyclope...used-cars.html
I only thought to look it up because I received a dealer warranty (as above) even though my 911 was still under its original warranty, plus the CPO warranty. I was triple covered for a month
The New Jersey Used Car Lemon Law requires a car dealer to correct a "material defect" of a covered item of the used car if the defect occurred during the warranty period. A material defect is defined as, "a malfunction of a used motor vehicle, subject to the warranty, which substantially impairs its use, value or safety."
The covered parts include:
Edit for wonky spacing
- Engine. All internal lubricated parts, timing chains, gears and cover, timing belt, pulleys and cover, oil pump and gears, water pump, valve covers, oil pan, manifolds, flywheel, harmonic balancer, engine mounts, seals and gaskets, and turbo-charger housing (Housing, engine block, and cylinder heads are covered only if they are damaged by the failure of an internal lubricated part.)
- Transmission Automatic/Transfer Case. All internal lubricated parts, torque converter, vacuum modulator, transmission mounts, seals, and gaskets.
- Transmission Manual/Transfer Case. All Internal lubricated parts, transmission mounts, seals and gaskets (excluding manual clutch), pressure plate, throw-out bearings, clutch master, or slave cylinders.
- Front-Wheel Drive. All internal lubricated parts, axle shafts, constant velocity joints, front hub bearings, seals, and gaskets.
- Rear-Wheel Drive. All internal lubricated parts, propeller shafts, supports and U-joints, axle shafts and bearings, seals, and gaskets.
