Need help with paint readings
Hi Guys. I have a 2013 C4S and just purchased a paint thickness meter for grins so I could detail my 1982SC. I measured the 991 and came up with readings that had a spread from about 6 to as high as 8 mil. Readings on different sides of the car in the same location were incredibly consistent to within typically 0.25 mil. I have platinum silver paint with very consistent color, metallic flake, and orange peel. Is this thickness normal for factory paint? I bought the car used and it only has 6K miles on it. If it were repainted, I have a hard time believing that the side to side consistency would be that good. Also I see absolutely no tape lines or overspray anywhere. I’ve heard everyone quote 4-5 mil as typical. What gives?
Maybe a new panel?
More likely that the paint meter is not calibrated properly. Go out to your daily driver, if you have one, or another car that you know has a factory finish and see if it reads normally. It isn't likely that your entire car was repainted. For detailing, always use paint meters as a guide. They are better used for knowing if a car has been repainted than knowing exactly how much paint you are removing.
Received 5,415 Likes
Post your question in our Concours Forum, too. The professional detailers there are taking paint readings every day.
Esoteric_Detail (02-29-2020)
Basic Sponsor
Secondly, get a chart (or simply do a rough sketch of the car) and go over the entire car, taking several measurements from each panel. From one side to the other, take measurements in the same spot on each panel. There is always going to be variation from one panel to the next, but the measurements should be relatively close from one side to the other (the driver's side door should be close to the passenger's side door, fender to fender, etc). This would be an easy first step to decipher whether the car has been repaired/repainted in its lifetime.
__________________________________________________________
ESOTERIC Fine Auto Finishing - America's Premier Exotic Detailer
Detailing . Paint Protection Film . Window Tint. Ceramic Coatings . Car Care Products . Training
HRE Wheels . Vossen Wheels . BBS Wheels . Akrapovic Exhaust . Fabspeed Exhaust . KW Suspension
9801 Karmar Ct. New Albany, Ohio 43054
(614) 855-6855
Contact@EsotericDetail.com
EsotericDetail.com
EsotericCarCare.com
ESOTERIC on YouTube
(614) 855-6855
EsotericDetail.com
EsotericCarCare.com
ESOTERIC on YouTube
Carlo_Carrera (02-29-2020)
First tip- switch your paint depth gauge to microns instead of mils. Microns are a smaller increment of measure, so they are going to be more accurate.
