Leather seats pealing?
I tried searching. Not much luck. Is this a defect or normal? Just purchased a 2017 cpo last month. Didn't get a ppi..i know, i know. The drivers seat is pealing where you butt goes and the part that extends and touches your hamstrings. I've never had problems with leather pealing in my infinity, Nissan, and Toyotas, so im kind of upset to see this. Still under factory warranty for another 6 months or so, then cpo. What do you guys think? Anyone else have this problem?
It rubs off pretty easily.
Not normal, the material is definitely coming up. Could be improper cleaning, or maybe someone was using a lotion or sunscreen on their legs which reacted with the leather and caused it to peel.
I would talk with the dealer that sold you the car and see if they are willing to do anything to make it right. Expect this to take a lot of effort. You can also talk to your dealer though and see if they will goodwill it or try and get it covered under warranty, but normally this stuff is considered wear and tear, not a warranty claim item.
CaptainL (01-14-2020)
The leather finish has failed, and should be covered under warranty, this not due wear as it appears the finish is coming off in areas that don’t get much wear (under the front edge of the seat bottom).
Leather seats, at times, have a painted finish applied and can be refinished. Don’t know for sure if Porsche does that as well.
I had a large crack on the bottom portion of the driver’s seat on my Mercedes, they replaced the entire bottom cover under my extended warranty, so coverage does happen on a “wear”’ item.
Yikes.
How many miles on the car?
I hope no one tried to hide seat wear by painting over the original surface.
If this isn’t from a fix then how did this happen. You bought a cpo car and everything looked great and was normal and then suddenly in the 6 months of ownership the leather coating fails. I say that someone tried to hide this and you have uncovered it. Bring it to the dealer and sow it to your sales guy and give him the keys and tell him to call you when they have come up with a solution.
Your damage has seemed to come from nowhere correct?
If it isn't a botch repair the only other thing I have seen similar was when a wet cloth was left on a seat for an extended period and it lifted the top coat of the leather right off. But that damage was immediately evident.
There is a third DIY option where you restore it yourself. Places like this sell the supplies. It seem crazy but it works, much better than you would think.
https://www.leatherrepairkits.com/au...sche&model=911
https://www.seatdoctors.com/porsche-...11-leather-dye
Received 3,460 Likes
Stay on topic all...there are misspellings, grammar issues, etc. in just about every post - IDGAF.
Anyway, let us know what the dealer says but I bet you are not going to like the answer. Did you see pictures of the seat before you got it? Or do you have pictures when you got it?
They might have the photos of the car that were taken to list the car on their site. See if you can get those. That will tell you if it was there before. Holy hell. That needs to get sorted out. And soon. Wait until you sweat a bit and it will look like you soiled your trousers. Yes, I said trousers. Someone might think that you crapped your slacks. Yes, I said slacks.
