PDCC or RAS - if you could only pick one?
I've read a lot on here about PDCC and RAS and I realize that this is subjective to a degree, but if you could pick one only - what would it be?
My build is a 991.2 Targa GTS and it is already getting up there in $$.
I am personally not going to track the car, but I enjoy spirited driving here and there. I live in a major city/suburbs so even that is limited.
Thanks to everyone for their past and future advice!
Do you want a smooth ride or do you want to feel like you are changing the laws of physics when you turn? Your answer will dictate your choice... If you can swing PDCC then RAS really isn't that much more. A few years, you won't even remember the price difference...
Luck!
ẞ
Luck!
ẞ
So which of the options would give a smoother ride? Pdcc ras or both?
I'd love a smooth ride for daily driving but the option to drive more spiritedly (is that a word?)
PDCC is active all the time, but the suspension and engine-transaxle mounts are both adjustable with the PDCC button. I like the flat cornering and softer ride combo it offers for rough streets and roads. You can set it to come jarring for razor sharp handling on smooth roads and track.
RAS is about having the shortest turning circle of all the Porsche sportcars, best parking maneuverability, and incredible high-speed anti-skid control.
Im spoiled, I want em both!
If over budget, I'd opt for a sunroof coupe over the Targa, instead of chopping performance options.
Received 3,460 Likes
All Targas have all wheel drive so it is a "4". And he is getting a Targa so forget the Sunroof Coupe (smart choice OP).
I drove cars with and without PDCC and RAS and I optioned RAS since I did not notice much of a difference with the former but did with the latter, and I could have had both but I did not see a reason to spend money on something that did not provide a benefit. Some do say they could tell a difference with PDCC but if you are not going to track and don't mind a little body roll I say skip it but as any option goes you should try and experience it. In regards to comfort a lot depends on the roads you frequent along with tire pressures.
Yojeffo (08-20-2019)
I track my car and don't have PDCC - I couldn't tell the difference with SPASM
This has actually been discussed a lot in the past: search this forum on "RAS" and "PDCC" and read the posts but again, if you can drive cars with those options you'll be able to decide.
RAS
I actually prefer the 911 without PDCC
On something like the Cayenne, PDCC is almost a must. On a 911? No.
I would spec them both because I like them both for the different purposes that they serve (as explained previously). I have the PDCC in my GTS (RAS was not an option) and RAS in my GT3 (PDCC is not an option). If I were pressed to choose one or the other, it would be the RAS as I agree with the others that the difference between PDCC and no PDCC is smaller than the difference between RAS and no RAS. The RAS is a game-changer. The PDCC is nice to have and definitely noticeable but it is not the game-changer the RAS is.
dsddcd (06-06-2020)
THANKS EVERYONE
smiles11 (06-04-2020)
