Plug or replace tire?
Quick advice.... A slow leak started in my rear tire.
Im losing 1 psi about every hour. Tire was down 20 psi this am . this isn’t exactly a slow leak but it’s not a blowout.
Before I waste my time: is a leak producing this rate of air loss one that can maybe be patched or should I just go right for a replacement? I can not find/feel the damage so it’s not a sidewall.
I know it’s not much to go on but I need to leave the car for a whole day just to find out about the patch and if you guys think: “ don’t waste your time, that’s too big of a leak to patch” then I’ll go a different direction
Class5Kayaker (07-01-2019)
All good advice given above. I would add that you should go to an auto parts store and buy a tire plug kit and learn how to use it. It is possible to generally plug a tire while it is inflated and on the car within 5 minutes - no need to hassle with leaving a car at a store, finding a ride, etc.
With the lack of spare tires these days, everyone capable should learn how to plug a tire for street use. Just don't push the limits and try to plug anything near the sidewall as noted above.
By the way, original Windex works great for locating leaks.
Good luck.
Good luck.
Just a thought, but I got a nail on my Cayman S and parlayed it past The Boss into a set of new Michelin P4S. Worth a shot.
0luke1 (06-29-2019)
Good luck.
Good luck.
TwinTurbo420 (07-02-2019)
This. Why take a chance?
Received 3,877 Likes
Any tire repair means the tire loses its speed rating and is compromised. Keep that in mind if you intend to drive your Porsche aggressively.
Personally, I will never plug the tires on my Porsche, I replace them. My old truck that I take to Home Depot - I have no problem at all with plugs in the tires since its not going very fast to the hardware store.
DIY plug kit s/b only for an emergency till you can get to a tire shop for a proper plug + patch repair, such as done by Discount Tire. (Assuming the leak is in a repairable area & the hole is not too big.)
If you need a new tire, you may want to either buy 2 tires or have the new one shaved to match the tread depth on the other side.
Not good to have significantly different tread depth on same axle.
