AutoTalent - Alpha Performance Porsche 991.2 Carrera Intercooler System
Old 06-14-2019, 08:07 PM
AutoTalent
Former Vendor
AutoTalent's Avatar
Default AutoTalent - Alpha Performance Porsche 991.2 Carrera Intercooler System
Matt@Autotalent.com
Introducing the Alpha Performance Porsche 991.2 Carrera Intercooler System
AMS developed the Alpha Performance Porsche 991.2 Intercooler System to provide you the best cooling upgrade for your Porsche 991.2 Carrera. In bringing these intercoolers to market our goal was to provide the ultimate system in terms of quality, simplicity, fitment, aesthetic design, and performance.
The Highest Quality Garrettİ Intercoolers For Your Porsche 991.2
The Alpha 991.2 Intercooler System utilizes Garrett Intercooler cores that are 50% thicker than OEM! Alpha’s massive cores give you the most power producing intercooler upgrade on the market by way of significantly cooling the charged air flow. Each of the two super thick 120mm Garrettİ cores provide an optimum fin density of 20 fins per inch for unmatched cooling.
Computer aided design yields maximum results
Our engineering team designed the Alpha 991.2 Intercooler end tanks with extremely smooth features and the perfect geometry for the best flow resulting in maximum horsepower. Designed using Solidworks 3D CAD software, these end tanks have improved flow over boxy sheet metal end tanks found on other intercoolers. We then took it one step further. AMS Engineers designed the organically shaped carbon fiber ducting to make use of every millimeter of available space for the ultimate power producing charge of cool air. The organic carbon fiber lower ducts allow the heat to transfer to atmosphere instead of soaking into the intercoolers.
Cooler Intake Charge Boosts Power And Response
Channeling cool air to the intercoolers is vital for optimum performance of any intercooler. Some manufacturers choose to remove the factory intercooler inlets in order to cut costs. This greatly reduces the effectiveness of ANY intercooler whether it’s larger or not. Others require that you cut up and tape the factory shrouding to the intercooler core in an attempt to seal the shroud to the intercooler core. While this is better than removing the shroud, it is still not the most effective way to boost performance. The Alpha Performance Intercooler kit requires no drilling and no cutting.
The Alpha 991.2 Intercooler System retains full use of the stock intercooler inlets forcing cool air into our larger, carbon fiber shrouds. Not only is this option more aesthetically pleasing, each rigid OEM-quality carbon fiber piece is made to seamlessly mate to the Alpha Intercoolers feeding them cooler ambient air more efficiently than the alternatives. Not to mention, eliminating the removal or destruction of your intercooler ducting. Included with the kit are velcro Alpha branded “speed straps” that hold the lower duct securely to the upper duct that will not deteriorate over time.
Maximum Airflow For Maximum Horsepower And Torque
Perhaps the best feature about this intercooler system is that it maintains cooling efficiency as more Alpha Performance power producing upgrades are developed for your Porsche 991.2. It improves the effectiveness of your other upgrades giving you maximum hp output potential.
Alpha Porsche 991.2 Intercooler System Upgrade – Carbon Fiber Ducting
High Quality Garrett Intercooler Cores
Alpha 991.2 Intercooler System speed straps and foam seal.
Exclusive Benefits
Highest quality intercoolers on the market
Smooth cast end tank design reduces turbulence
Optimum fin density of 20 fins per inch for improved cooling
CAD design achieves perfect fitment and provides the most potential for power
Carbon fiber intercooler shrouds and our foam tape form a tight seal to maximize cooling efficiency
A simple installation without having to perform unsightly modifications
High quality materials to last the lifetime of your 991.2
Provides a factory fit & finish unmatched in the automotive aftermarket industry
Includes
120mm thick Alpha Intercoolers w/ cast aluminum end tanks
The highest quality carbon fiber intercooler shrouds
Foam stripping
Alpha Branded Speed Straps
Applications
2016-2019 Carrera
2016-2019 Carrera Cabriolet
2016-2019 Carrera S
2016-2019 Carrera S Cabriolet
2017-2019 Carrera T
2016-2019 Carrera 4
2017-2019 Carrera GTS
2017-2019 Carrera GTS Cabriolet
2017-2019 Carrera 4 GTS
2017-2019 Carrera 4 GTS Cabriolet
Kit Instructions
Alpha Performance Porsche 991.2 Intercooler System Install Instructions can be downloaded here.
How to Place Your Order:
Phone International: (855) 973-2757 X 123
Phone Domestic: (310) 231-7800 X 123
E-mail: Matt@AutoTalent.com
Website: www.AutoTalent.com
Payment:
Attachment 1345656
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
Old 06-15-2019, 02:21 PM
Norge911
Norge911's Avatar
A must have for anybody with a tune.
Old 06-16-2019, 06:12 PM
4 Point 0
4 Point 0's Avatar
Received 1,192 Likes on 630 Posts
I bought these from COBB with the tune. Now Garrett needs a direct bolt on replacement Ball Bearing Turbo's for the GTS. : )
Old 06-16-2019, 08:43 PM
PTS-BRG
PTS-BRG's Avatar
4 point 0: What are your thoughts on these intercoolers and intercoolers in general for GTS? If I am not tracking the car ever, is it really necessary? THX
Old 06-16-2019, 10:46 PM
4 Point 0
4 Point 0's Avatar
Hey PTS-BRG, if you are never tracking the car, then they are not necessary.
If you lived in an extremely hot climate, or you wanted every ounce of performance possible, then they are nice to have. But definitively not necessary.
I live in an extremely hot climate.
I want max performance.
I am a track rat.
So yes, for me, it was necessary. YMMV.
Old 06-16-2019, 10:49 PM
PTS-BRG
PTS-BRG's Avatar
Thats what I figured as well. Thanks!
Quick Reply: AutoTalent - Alpha Performance Porsche 991.2 Carrera Intercooler System
