Targa 991.2 Build
Received 3,364 Likes
Good for you! Do you have the build code so we can check it out? Is it locked yet?
Thanks, here is the link to enter the code to make it easier if someone wants to see it: https://www.porsche.com/microsite/po...checode&pc=&c=
Nice, and I will not suggest changes since it is your car; however, a couple no cost items many get are the net in the passenger's footwell and smoker's package.
Some do noy opt for the aluminum shift **** since it can get hot and it feels heavy but I did not option it and wish I had. I do not keep mine in the sun and while the factory shifter **** is fine my wife wants a heavier one (go figure). Anyway, if you order it and want to trade me keep me in mind and I would appreciate it, and I will pay the shipping, etc.
You have a beutifull configuration!!!
My 1-month old 2019 Targa 4S has the same Carrara White with the Graphite Blue/Chalk interior and same wheels. My top is blue and even my instruments and chrono are white as yours!!! Only the seats are different; mine are the 14’s position.
Just consider the following:
My best wishes to you for a long term GTS Targa enjoyment.
- The fuel cap is only visible just when refuel. Unless you like it so much you can save some dollars there.
- Rear axle steering is wonderfull at slow speed while park/u-turns. If you plan to track, in my case I will not, there are some extra advantages.
- Power steering plus also facilitates parking maneuvering.
- The adaptive cruise control is amazing during comute but not sure how much benefits provides under manual transmition as yours (I have the PDK).
- Depending on your location weather the seat ventilation is recommended. I am at carribean and always use it with the top down.
- Illuminated Door Sill Guards in Stainless Steel looks amazing.
- I have and like so much the easy entry but for is not a must on my opinion.
- My interior has the brushed aluminum but standard trim is fine.
- As other member mentionged get the free-cost options: pasenger floor net and the smoking option which provides a charged with a cover.
