reapplying rear badging
Received 5,388 Likes
Originally Posted by KP993
This is what I did. Bought the GTS badge from Suncoast.
Yes and yes.
I believe the placement of his "GTS" is same as the factory location of the "Carrera" emblem so i don't see how the "GTS" looks "low".
What i'm saying is since he left the "PORSCHE" in the factory location and simply removed the "911 Carrera GTS" then put the "GTS" where the "Carrera" was originally then the "GTS" should be at the same height at the factory "Carrera" location not lower.
LexVan is right. Mine has the model designation delete option so the placement of PORSCHE from factory is lower than yours with model designation. So if you remove the 911 CARRERA GTS and replace with GTS than the location should be perfect.
Porsche GTS
I just bought a Chalk 2019 Carrera GTS with 1,500 miles. The original owner was a Porsche exec, and the car was ordered completely debadged for some reason. I just ordered the Porsche and GTS badges from Suncoast and would like to do a badging job similar to the original poster. I’m taking my car to be done at a Porsche certified auto body place. I assume they will have the template? Are the badges to be arranged so that the space between the Porsche and GTS lines up horizontally across the center of the rear deck lid between the taillights?
Received 3,364 Likes
You will need to buy new one and as other members mentioned, you really can't install them yourself. you will need a special tools to align properly.
One of my buddy did with matte black vinyl which you can do it yourself so it could be alternative option for you. Here is a picture of mine with GTS only (dealer installed).
Maybe it is the angle you took the pic but the GTS does not look proper to me. The "T" should be centered on the "S" above and the others straight - the "G: looks like it is leaning one way and the "S" the other.
