Tarret Caliper Studs
If the ones you order don’t come with the sleeves my advice is to order sleeves for all of the studs. They say that the shoulder is sufficient to center up the caliper but I found that the sleeve over the stud felt a ton better for locating the caliper. Depending upon how deep the chamfer is in the aluminum suspension arm there isn’t much shoulder engaging the caliper.
I found the website to have some odd qwerks. It did not always show all of their products unless you went through the right sequence of clicks. When looking at the caliper studs, click on the picture of the studs and it opens a new page. Then go to the bottom and you will see accessories. It shows the sleeves in that view. I installed Girodiscs when I did my upgrades and had all sorts of problems. I also had to email them to confirm what to order. This link hopefully works too: https://www.tarett.com/items/un-assi...bcs-detail.htm
Good luck.
Good luck.
