Rennlist - Porsche Discussion Forums (https://rennlist.com/forums/)
-   991 (https://rennlist.com/forums/991-221/)
-   -   Comfort Access Improvement (https://rennlist.com/forums/991/1141596-comfort-access-improvement.html)
Bob Z. 05-05-2019 02:29 PM
I have the Entry & Drive option but the seat did not move back nearly enough for me and I had to manually move the seat back, up until now. I set one key to save my driving positions, which is stored in #1 and I set the other key to save settings in #2 that move the seat all the way back and the steering wheel in & up. So now when I open the door I push #2 to move the seat/steering wheel and after I sit down, but before I close the door, I push #1 so I am ready to drive. And when I stop driving I open the door and push #2 for much easier exiting. Finally, I unchecked Comfort Access in the settings since there is no need to have it move otherwise.
MGC 911 05-05-2019 04:47 PM
There should be a way for your seat to move all the way back upon unlocking the car. And then automatically move back into position once you close the door. That’s what mine does.
Bob Z. 05-05-2019 04:54 PM
Originally Posted by MGC 911 (Post 15820235)
There should be a way for your seat to move all the way back upon unlocking the car. And then automatically move back into position once you close the door. Thatís what mine does.
Comfort Access, when selected in the settings, only moves the seat back a couple inches, which is not nearly enough for me based on where I have my seat placed for driving...others have reported having the same problem. My wife's SUV has comfort access and the seat goes back at least 6", which is ideal.
Porsche_nuts 05-05-2019 05:27 PM
My seat moves like Bob's, only a few inches. If there is a way to move the seat all the way back with comfort access, please let everyone know. I have a .1 and I think Bob has a .2.
Bob Z. 05-05-2019 06:17 PM
Correct, I have a .2 and there is no way to make it move all the way back with Comfort Access alone; however, if MGC 911 can prove me wrong I, and many others, would like to know what how you made it happen.
MGC 911 05-05-2019 09:52 PM
I’ve never noticed how far back it went. I’ll check next time I get in.
Valvefloat991 05-05-2019 10:27 PM
If it goes back too far, you won't be able to depress the clutch pedal to start the car.
Bob Z. 05-05-2019 11:24 PM
It only goes back in order to get in & out of the car easier (read post #1).
Valvefloat991 05-06-2019 12:08 AM
I understand, but the OP seems to want it to go back further. I'm simply offering a possible reason why it doesn't do so.
MGC 911 05-06-2019 12:35 AM
correct. Mine is the same. It moves back 2-3 inches. Not all the way back. I had never noticed that because it wasnít really a problem for me.
the_buch 05-06-2019 12:49 AM
Now this is a first world problem :)
ipse dixit 05-06-2019 11:48 AM
I think this is the correct answer
Bob Z. 05-06-2019 12:01 PM
I think people are missing the point here. Comfort Access is supposed to move the seat back to make it easier to get in and it not supposed to stay all the way back! Did anyone read my initial post? I am not saying it should move the seat back and stay there!
Stevelev 05-06-2019 02:05 PM
I too would prefer an extra couple of inches of space but I think the point is that the seat doesn't reset to the "driving" position until one starts the car. Reaching the clutch is a requirement of starting the car Ö Now if the seat reset once the driver door was closed, it would be ideal for the seat to go much farther back.
Bob Z. 05-06-2019 02:25 PM
That is incorrect. I started this thread to show everyone a way to make comfort access more comfortable! If you have Entry & Drive you can set one key to switch 1 on the door and the other key to switch 2 on the door. I have been doing this and it works perfectly and when I press 1 on the door after I get it, and before I close the door the seat and steering wheel move to my driving position. And if I forget to press 1 before closing the door I need to press and hold 1 until it gets to my driving position.
© 2019 MH Sub I, LLC dba Internet Brands
