Manual transmission .... 2014 C4S
Hi all. Just got a 2014 C4S. Coming from a 997.2 with PDK.
When releasing the clutch I feel a lot of mechanical movement from the chassis. A “clunck”/thud of sorts. I’ve driven manual all my life so that should not be the issue. It happens when moving from a stop and while on the go. Release is high and if I bleep I may avoid it ... but not always.
Is this the nature of the beast or are the mounts failing? I did the 3rd gear, low rpms and uphill pull and clutch behaves very well.
Service guy says it is normal for a performance car. States it is gear “whip lash” from a high power engine.
Thoughts? Any test I should run?
Received 3,365 Likes
My C7 had it at times and I hated it, and it was just one of the reasons I got rid of it, but I have not experienced in my 991.2, nor the 3 manual P-cars I have had in the past.
2017 C2S
There is another thread about this. I get a slight clunk whenever I shift into 1st or reverse while stopped. Something to do with the input shaft as I recall. It seems to be normal operation.
Sounds like driveline lash? I've only had it in my trucks. My Land Cruiser has it occasionally.
I don't think it's something to simply accept in a Porsche - I've never driven one that had it. Motor mounts/transmission mounts come to mind. CV joints and diff.
Edit: I noticed you said you are blipping on upshift. My s2000 had a tendency to quickly drop RPMs and I would have to blip on upshifts occasionally to keep it smooth. I had a GT4 and have driven manual 911s and never saw anything like that.
We love it. Comfortable, indestructible. I can go off the grid and feel confident that I'm pretty much able to get out of any jam I might find myself in.
That said - it's pretty much the opposite of a Macan. It drives like the body on frame truck that it is.
No clunk here buttery smooth
