Firming Up the Non-GT Car Suspension
Good afternoon all, I recently sold my GT3 Touring and plan to pick up a GTS soon. The GT3 is an amazing car but not the right car for what I want to do, primarily long trips with occasional track use.
Ultimately the only thing that the GTS lacks for me is the sharpness in of the GT3. Ultimately I would like to do a hybrid setup where I might utilize the stock Sport PASM with upgraded bushing and potentially a single rate spring kit much like the ones available through Elephant racing.
So I was hoping that we might have a few that could offer suggestions on getting the suspension somewhere between the GTS and GT3.
(1) Front & Rear Adjustable Sway Bars
(2) Elephant Racing Coil Over Kit (Little to No Lowering)
(3) Front Offset Camber Plates
(4) Front Power Flex Lower Control Arm Bushing
(5) Rear ??????
(5) Rear ??????
Personally, I like the PDCC option. It takes a lot of slop out of the handling while still offering a comfort mode for rough streets and roads.
On my 991.1 C2S with PDCC I did the following and it helped A LOT with making my car feel more responsive and stable on high speed turns.
-Bilstein Damptronic Coilovers to lower the car and refresh my stock suspension, I have 60k miles on car
-Elephant Racing offset camber plates up front to allow for more negative camber (-2.5 up front) If you want more negative camber you can get GT3 lower control arms and switch out the rubber bushings for monoballs.
-DSC Unit - This will probably be an easy way to fine tune your suspension feel without getting too much into the mechanical stuff - Try this first to see what improvements you can gain from just software adjustments for your suspension.
-Function First Transmission Mount - really tightened up my shifting (7MT) and throttle response. I went with their softest mount, any more would be too much for me.
Great advise so far, thank you!
I do have a DSC which was used on prior cars and would plan to throw that in and do some testing.
There would be no issue with running the Monoballs but best I can tell the price for a set is something like $5K for the parts which seems steep. My last race car used a very high quality set and the parts, more bushings that the 911, were a fraction of the cost.
BTW, I do like the Elephant racing option over many others as you have choices of linear springs versus progressives that I have on my damptronics. Not sure what type of springs are on the KW HAS kit.
Good of luck and keep us updated on any modifications. BGB Racing has a thread on here as well on all the mods they did to their GTS. Made it way faster than a GT3.
i asked Tom at TPC for parameters to change to reduce dive during breaking and hard cornering, but instead he created two new files, firm and extra firm that he then emailed to me. Best service and files are excellent. So before buying hardware, ask if Tom has files he can share with you and try those before you spend to much money.
At the moment My choices are, an adjustable single rate spring set, offset top hats and at least one adjustable sway bar (rear preferably). Pair that with OEM tires sizes say PZ4 or PS4S’s and call it good.
The difficulty right now is the amount of camber required. When I ran my Turbo S in OLOA within a few events I wore the outer edges of the 4S’s in the rear. The Perrelli’s PZero’s did not suffer the same fate as the outer tread is not as hard though the new PZ4’s might need more camber also. Anyway Picking the wrong camber is a $1000 mistake so any advise there would be helpful.
I typically put 15K or more miles a year on my Touring Car. Last year it was a Turbo S and before that FType R, C7 Z06 Vert and many others. For those, which is 95% of the people buying them, that put some miles on here an there I can't think of a more fun and exhilarating car. The shiftier is like a fine watch, engine an operha, the ride smooth yet confident and they are amazing on track. Though I did not track mine I have driven a .2 GT3 and owned a GT4 both of which were lots of fun. Since I already have a track car the GT3 T was not a good fit in the stable and thus I ordered a more suitable match in a GTS RWD. This car will see 95% street and offers big low end torque, over drive, full sound insulation but is not as bloated my Turbo was. All that and with some good tires should match or beat a laptime of a GT3, with a tune and some sorting of the suspension it should leave a GT3 on track.
So that brings us to this thread if I can add some of the suspension precision back into the car that the GT3 had it will be the perfect GT car for my wants. Then who knows maybe a GT3 T or GT3-RS without a wing will be on the bucket list in the future.
