Can you swap out regular steering wheel for MF wheel?
Anyone know if this is possible and if so, how difficult is it to do?
I have a 7MT and a sport design wheel but want to replace it with a multi-function wheel.
SJW, a Carin' kinda guy
Suncoast used to advertise that you could (and needed $700 in part to do so, I assume the clock spring and the MF stalk delete parts), but now say you can’t. I also understand you used to get a code to put in PWIS to activate MF. I’d call Ric and suncoast and ask.
If your car is a .1 its a straight swap (airbag carry over).
You'll need a cheap Porsche bolt, some programming and the wheel and the control stalk.
If you need a low mileage MF wheel, PM me, I'm selling mine with the control stalk also - I went the other way and upgraded to a Sport wheel.
Good luck
Good luck
Looking at your avatar - you have a .1? If that's the case, you will not need a new airbag.
What is a/the clock spring?
AFAIK, you need the wheel, column stalk and dealer programming only.
Ah I see. I'm not sure how the MF works in the .2.
In my .1 the MF wheel comes with a three column stalk (lights, wipers, cruise).
With the sports wheel, a new stalk is supplied with a 4th column, for the MF.
Hope that helps!
Hope that helps!
Good luck
Good luck
Yes I have a 991.1 so it seems there will not be an airbag issue. I will send you an PM Rezok.
