Ok to put a little cleaner wax (edit: with petroleum) on PPF?
So turns out the cleaner wax I used has petroleum, which is supposed to be a no no on PPF. I guess my wonderment/paranoia is whether using it this one time can cause premature degradation of the PPF. Or if it'll wear down some protective coating PPF has. So far it looks totally fine and normal.
Xpel PPF:
Paint Protection Film
Can The Film Be Waxed?
While you can wax the film, be sure the product you are using doesn’t contain Naphtha or Kerosene in concentrations over 5%, and also avoid waxes that contain dyes. For best results, we recommend using our XPEL Flawless Finish Paint Protection Film Sealant. This product has been specially formulated for use with polyurethane paint protection films to provide the maximum protection and gloss, while containing no ingredients that would cause discoloration over time.
I use the XPel manufacturer brand cleaner and sealant. The cleaner works good. The sealant is AMAZING!! It gives my PPF a deep pearl look.
I have used the Chemical Guys Wrap Detailer in the past. I compared both MSDS sheets and they are similar.
Basic Sponsor
What to Use to Polish Paint Protection Film
I know, I know, ANOTHER freaking PPF thread in the 991 forum.
I just had to put a little cleaner wax (synthetic) on a little portion of it due to some hard water spots that weren't easily coming out. Is there any aspect of element to PPF that can harm? I know cleaner wax is an abrasive that can "strip" clear coat, but at the end of the day I assume since PPF is plastic, as long as it doesn't eat through (which would never happen) it should be fine?
Polishing film with typical polishes or compounds will speed up the sun damage, because they are removing the protective features of the film and exposing the deeper layers of the film to more UV rays.
You can definitely use a carnauba-based wax on film, but we would recommend using a non-petroleum based sealant that will last longer, on top of being easier to apply. Quartz/Ceramic/Glass coatings are superior protection for the film, because they offer a measurable layer of cured material that will serve to protect the film for the longest amount of time.
__________________________________________________________
ESOTERIC Fine Auto Finishing - America's Premier Exotic Detailer
Detailing . Paint Protection Film . Protective Coatings . Car Care Product Sales . Training
HRE Wheels . Forgeline Wheels . BBS Wheels . Akrapovic Exhaust . Fabspeed Exhaust . KW Suspension
9801 Karmar Ct. New Albany, Ohio 43054
(614) 855-6855
Contact@EsotericDetail.com
EsotericDetail.com
EsotericCarCare.com
ESOTERIC on YouTube
(614) 855-6855
EsotericDetail.com
EsotericCarCare.com
ESOTERIC on YouTube
You should not use abrasives with paint protection film, as this will lead to degradation of the top urethane layer of the film, speeding up the aging of the film. Check out Gyeon PPF Renew, which is a chemical cleaner that was designed from the ground-up to clean and refine lightly-aged film.
This is false- yellowing comes from the top urethane layer being damaged by UV rays from the sun. Modern films warranty against yellowing, but older films can be very susceptible to the problem.
Basic Sponsor
UV does age PPF, as well as paint and carbon fiber . But PPF acts as a UV barrier to protect the paint , as it does for road rash.
Too much wax and detailer can build up and cause stealing. Washing with Dawn dishwashing detergent in warm water removes that.
Here is the product my Chicago concours winning buddies use on PPF:
