Sport mode when first driving to warm oil up quicker.. yay or nay?
I've read a lot, on this forum, that Sport mode "opens" a secondary oil cooler that helps manage high engine temps. And I have indeed noticed a significant drop in oil temp when driving fully warmed-up car. So it seems to me that cold driving in Sport would hinder warm-up by way of the additional oil cooler. (unless the computer only access it after a certain oil temp is reached).
The engine warms up quicker in normal mode due to cooling system design and the need to meet emissions requirements. The PDK probably does warm up faster in Sport mode, but whether this is a good idea or not, I have no idea.
That's been my experience also. Engine oil warms faster in normal mode.
Originally Posted by reacher
The first thing I do right after starting the car is put it into sport or sport+ mode, without fail. I can't think of a single reason this would be bad for the car if you warm it up properly.
I also always drive my cars in manual mode so there's no issues with it getting the revs up too high in those modes before the engine is warmed up, which could be an issue if you leave it in auto mode. (Not sure why anyone would want to drive these cars in auto mode at all, but that's a different subject.)
RPMs are what I care about and in sport mode in auto, the PDK might hang on to a gear if you aren't paying attention while the engine is cold
Interesting. The "downside" to normal is that it shifts too early, which takes a lot longer to warm up (in traffic I can drive with barely getting the revs up, so in city driving it can take a long time to get up to temp). Sport "upside" is that it holds the revs higher (but not too high), but "downside" appears to be that it may actively cool the oil even when the oil is cold. So seems the ideal setup would be normal with holding revs like sport mode (and keeping under 3K RPM) during warm up.
You will have a hard time keeping the car off boost even in normal mode. I don’t think there’s much risk in letting the turbos spool. If you keep the revs low enough during warm up and don’t give it WOT then boost will never reach anywhere near max anyways.
So it sounds like the car warms itself faster in normal, but sport revs higher so that supports faster heat up. But, if you have a manual, then there's no reason to put it in sport. Do I have that right?
Typically I let it go to about 170 or so and shift like a granny in Normal, then pop in Sport. Thank goodness for the dedicated PSE button!
Not true. I have a 911 T with a manual transmission and when accelerating to 60 from a stop leaving my neighborhood & keeping RPM's below 3000, boost stays at 0 in Normal but is 1-3 psi in Sport no matter how lightly I apply the throttle.
I have decades with numerous Pcars driven to 135 - 150K miles with no internal engine issues. My standard is not above 2K RPM before oil temp is at 140 degrees. Every race mechanic I've had has said the same for my race cars. For my PDK 991 I have to hit the paddle a lot to keep it under 2K but it's possible. I'm certainly an eager beaver but not worth it for an expensive street car has always been my thoughts. So I miss 15 minutes on each drive.......
congratulations, but my point was there’s no risk in having the turbos spool up a little.
Here's some actual 991.1 data although my 991.2 is no different:
Key
NA: normal auto
SA: Sport auto
NM: normal manual
SM: Sport manual
SP: Sport+ manual
https://rennlist.com/forums/991/9738...emp-study.html
Key
NA: normal auto
SA: Sport auto
NM: normal manual
SM: Sport manual
SP: Sport+ manual
No need to watch boost levels here either.
Wow, 2K?! Didn't even know you can shift it that low without practically lugging, but I guess if you really granny shift. I don't think I can adhere to that as it'd drive me nuts. But power to you if you can.
Hmm. Am I reading this right in that it states the car warms up quicker on Sport Auto?
..... Wait. I get it now. I'm assuming it's not stating warm up time for equal RPM's, but it's stating sport will warm up quicker for the obvious reason as it revving more.
Key
NA: normal auto
SA: Sport auto
NM: normal manual
SM: Sport manual
SP: Sport+ manual
Key
NA: normal auto
SA: Sport auto
NM: normal manual
SM: Sport manual
SP: Sport+ manual
