Odb2 location 991.2 GTS
Hi! Anybody know the right location of the Odb2 port in the 991.2 GTS, It is not in the fuse box as in 991.1.
Thank you!!
Thank you!!
Received 3,364 Likes
Really?!
Just above the left dead pedal. Your left toes almost touch it.
Thank you will take a look again!
Bump for a helpful post
The manual clearly shows it in the fusebox, and there it isn't , just the hole is there it should occupy.
And facing down like it does makes its purple identity tricky to see.
Here is a pic I just took in my 2019 GTS Coupe:
https://www.nerdwallet.com/blog/insu...romile-review/
