P O R S C H E side stripe decals
Hi all,
I've got some 'Porsche side stripe decals. I was wondering if anybody has these from the factory and has the measurement of the placement please?
Below is an example of the decals:
Can this be of any help if I get you the measurements?
Received 3,365 Likes
Here is place that sells some as well, very high quality. I have been talking to them about a small decal to cover the cupholder symbol on the dash trim (running out of things to do):
http://www.acromann.com/index.php?ma...3db77ohm1rltj5
Appreciated all the input!!
This is perfect and will help a lot. Hopefully I don't cut the paint when trimming off the edge on each side
Originally Posted by paxton
Here you go
Attachment 1299576
Gave these instructions to my installer and turned out great
Attachment 1299578
Attachment 1299576
Attachment 1299578
Here you go
Attachment 1299576
Attachment 1299578
Attachment 1299576
Attachment 1299578
Hey Paxton, I quite like your black door handles. I guess its a thing. When they colour code them, they look nice black. When everyone has Black, they look nice colour coded. LOL.. The Black looks great against the white.
I see you have the white side skirt. I may do something with carbon later. I just got the Carbon Akra diffuser. You need tint to finish it off. : )
Twins
Contact Renndecals they make the decals and must be able to help with fitment and placement of the product ..
https://renndecals.com/
DO NOT put the stripe over the factory stone guard since it is thick and will get nasty over time so just have it removed first and you can get stock ones to go over them afterwards or PPF as was mentioned.
You may want to get a pro to install these for you, if you can find one. Sounds easy, but the slightest misalignment of the stripes , even 1mm, will be noticeable. Then it'll bug you every time you walk up to your car. Ultimately your call.
Amd if you have a real good window tinter around they can install them if there are no good PPF shops.
When my new 911 needed some factory stripe replacements, my dealer Svc Mgr sent me to a graphics shop that does a lot of race cars - Cutting Edge Graphics outside Chicago. Cutting Edge Graphics does a lot of race cars, including the Weathertech race cars and collectibles. He said typical wrap shops never get the placement correct because they are usually just stretch, cut and trim shops. Many don't typically do stripes. You need one with a lot of experience in applying graphics. Cutting Edge Graphics did a great job.
