Re-badging 991 with PORSCHE letters
#32
Received 3,364 Likes
OP - Note the letters are on the same level as the points on the taillights and yours are higher, which I assume you know by now based on the recent posts.
#37
Bottom. Use the detailed diagram shared above. The duplicate colors means they share the same measurements.
The letters are positioned ever so slightly different on certain letters to make a very subtle arch. It is not correct to use a straight edge and line them across like Scrabble :-)
trust me on this. I work with type all day.
#39
Also, I just measured this one from the dealer which is just PORSCHE with model delete. https://www.porschebellevue.com/new/...cd254ea359.htm
I went and measured it, the distance from the top of "S" to the top edge of the bumper was 2.4675" (which is less than 2 11/16 or 2.6875").
#40
#41
#44
While on the subject of lettering and re-lettering, what is the best way to remove existing letters without damaging paint/clearcoat?
