S Brake Kit cost?
Received 3,365 Likes
Please be aware that in order to upgrade from Red S / GTS brakes to PCCBs you need also to replace the brake pump.
This is the information I got from my AD.
Brake pump of PCCBs is different that normal brakes.
I hope someone can confirm my information.
Basic Sponsor
As an FYI to you gents considering brake upgrades, we are getting ready to release our front and rear Essex Designed AP Racing Radi-CAL Brake Kit for the 991. Our 991 GT3 system is 33 lbs. lighter than the OEM 991 GT3 iron setup, and closer to the PCCB weight, eliminates the need for caliper removal to swap pads, has ventilated stainless pistons, anti-knockback springs, 84 vane J Hook discs...the list goes on. You can see tons of details, owner feedback, and on-car pics of our 991 GT3 offering in this thread: https://rennlist.com/forums/991-gt3-...t-finally.html
In terms of size, hardware, and price, our 991 system is going to be nearly identica to our 997, 981, and 718 setups which can be seen in the links below. Our front system is designed to be as big as one can comfortably fit inside an 18" wheel. There isn't anything else on the market remotely close in terms of performance, and this is as close as one can get to AP Racing Radi-CAL setup the 911 RSR won Le Mans with in 2018.
Front 997 Radi-CAL Brake Kit
Rear 997 Radi-CAL Brake Kit
Our engineering director is taking final measurements on the 991 this Friday, and we will be moving to production of these kits immediately thereafter.
Installed on a 991 GT3RS
Here they are on a 981S with a secret admirer.
Caliper comparo vs. 991 GT3 components
'09 Carrera 2S, '08 Boxster LE (orange), '91 Acura NSX, Tesla Model 3 Performance, Fiesta ST
Jeff Ritter
Mgr. High Performance Division, Essex Parts Services
Essex Designed AP Racing Radi-CAL Competition Brake Kits & 2-piece J Hook Discs
Ferodo Racing Brake Pads
Spiegler Stainless Steel Brake Lines
704-824-6030
jeff.ritter@essexparts.com
Jeff Ritter
704-824-6030
Basic Sponsor
Our Essex Designed kits are available through any authorized AP Racing distributor.
I would start a dialogue with Tim Phillips at Circuit Supplies, but you can always feel free to contact us with questions. Thanks!
CIRCUIT SUPPLIES (U.K.) LTD
Unit 8, Eden Court
Chartwell
Leighton Buzzard,
Bedfordshire,
LU7 4FY
Tel:01525 385888
Fax:01525 385898
Email:info@circuitsupplies.com
Web:http://www.circuitsupplies
True, true, and Brembo owns AP Racing...which is also interesting.
Unit 8, Eden Court
Chartwell
Leighton Buzzard,
Bedfordshire,
LU7 4FY
Tel:01525 385888
Fax:01525 385898
Unit 8, Eden Court
Chartwell
Leighton Buzzard,
Bedfordshire,
LU7 4FY
Tel:01525 385888
Fax:01525 385898
Basic Sponsor
That is correct. Our systems use iron discs, despite weighing a similar amount to the carbon discs. The big difference is that our spare iron discs will last longer when abused on track, and cost $399 each vs. a couple thousand each!
GMP sells a Brembo kit. All it it's about a $25k upgrade. Other companies offer similar kits, Racing Brake is one of them. Seems a lot to spend just on brake dust, but not my money. Might be cheaper to just trade the car for one that has PCCB.
https://www.gmpperformance.com/produ...-kit-by-brembo
No, the master cylinder is different between a GT3 and non-GT3. It's not the rotor/caliper combo you choose that changes that.
The AP Radi-cal kit with some low dust ceramic pads might be a good option. Or just switch pads on your stock brakes to Centric Posi Quiets. Use them on our cayenne and on my last 991C2S and eliminated dust that way.
I think the OP wants Ceramics just to minimize brake dust.
So it needs a brake bump change as the master cylinder is different right? In any case the cost of brake pump is around 500$ therefore not a big deal comparing to overall PCCB upgrade cost.
If you upgrade to PCCB, you don't have to change any of that.
If you buy a Carrera S with PCCB, you get a Carrera Master Cylinder.
If you buy a GT3 with iron, you get a GT3 master cylinder.
The feel is different, other than that I don't know why there is a difference.
