2 Step limiter on porsche 991.
Hello ,I’m interested in buying a porsche 991.1 carrera s with a manual transmission,so if i want the motor to limit itself so i there can be some popping in the exhaust.
Is it possible to install a 2 Step limiter on a porsche 991 carrera s?
Thanks in advance.
Thanks in advance.
Received 3,365 Likes
Not quite clear about what you mean about a limiter but if you will get exhaust pooping in Sport mode, and a pair of high-flow cats will make it sound much better.
It pops and bangs with PSE very easily even with just some throttle modulation.
You need a turbo first...
Then you'd need to get a tune with a limiter function.
Possible, yes. Not at all easy.
Probably could be done with a 991.2 once the tuning is properly figured out. I wouldn't do it unless you're actually racing.
Followed your instructions ..don't know where to begin. What did I just watch??..Speechless...
Literally, I'm laughing at how ridiculous this is...
