DIY Car Audio Speaker Upgrade
I have no doubt that the Musicar tweeters would make a noticable improvement over stock. The Dynaudio tweeters they use are supposed to be really solid and those guys really know their stuff. Or, if you ever wanted, you could buy a set of morel mt250 tweeters (~$350) and I could just print you a set of the brackets I made. :-)
Yes, I’m serious. The upgraded Bang Olufsen in my S5, is terrible and it has a subwoofer somewhere. It’s very clear, but no deep, smooth bass at all. The Q7 I have has a crappy system too. My Hellcat has a Harmon Kardon that is just cheap sounding. It actually has two 10” subs in the trunk, from factory, mounted where a spare tire would be. The bass is sloppy and too loud. The 911, when you turn it up just a bit, has a nice blend of everything. I do like it a lot.
Hello
I just want to tell that I just finished the installition of my new head unit for my Porche 911 2009
It was not easy but I am happy.
And yes its not spam i just want to save your time.
http://smarty-trend.com/447-porsche-911-997-2004-2012
I just finished installing the unit from NM Automotive. Absolutely worth it! If you don't have a reverse camera, this is a fantastic way to add one as well.
I'm looking at doing a very similar audio upgrade. I'm waffling in what direction to go. I have a nice Pioneer head unit I've debated installing, but to be honest, I like the PCM 3.1 fine (and I don't miss Carplay one bit after using it for a couple years in my previous car).
Did you consider keeping the ASK amp and just upgrading the speakers to something a bit nicer?
PS: If you have a mulitmeter & your old speakers, I'd LOVE to know what they ohm out to... I'm guessing 4 but who knows? Internet doesn't offer any answers that I can find.
this is excellent. and 2 -10's in that car must rock. agreed on the bose, too bad i have it as well, i would certainly do this. I did a very similar thing in my truck as you did here. JL audio all around. i love listening to music in that truck..congrats on the upgrade!
If cost is of concern, I imagine you could piece something together with a 2 or 4 channel amp that runs through a passive crossover to a 3-way component system. The key would be finding the right component system with a woofer that is shallow enough to fit in the door so as not to interfere with the window sliding down.
I don't have a multimeter unfortunately. I'd guess that the base speakers are 4ohm, but then again I read that the bose setup is some mix of 2 and 1 ohm. Sorry I can't help you there.
For me, I was pretty set on replacing the amp from the get go. The only way I'd consider keeping it is if I was just doing a tweeter swap. That ASK amp isn't worth what it weighs (and it weighs next to nothing) If you are considering upgrading the door speakers, I think you basically have to do the amp too. There is no way that thing would be powerful enough to push anything larger in the doors.
With speakers of decent sensitivity (>90dB), the amp (according to the link) should have plenty of power to push the speakers into very uncomfortable SPL level in our small cabins. Or so some back of the envelope math leads me to think.
Your build is sweet, though. How did you decide between the Morel 903's and the Dynaudio 362's? Woofer depth?
4 ohms is what the link above says, and that's what I was guessing. It's pretty standard.
Would you be willing to share the. STL file for the tweeter bracket? I have access to a 3D printer and could print them myself. I'll send you a pm.
Also do you see any problem using the Morel tweeters with a Bose system?
Cysco and I have been exchanging notes, so I doubt he minds me posting this here. I upgraded my tweeters, and since nobody goes to the sound/video subforum, I figured I'd drop a link to the post from here.
https://rennlist.com/forums/audio-an...r-upgrade.html
I made some 3D printed adapters for the 4" mids in the doors & rear of the 991, and figured I'd share them in here.
https://www.thingiverse.com/thing:3449073
msdos (01-04-2020)
