Question about Spacers
Old 01-10-2019, 02:01 PM
mfonseca
mfonseca's Avatar
I would also like to see pics of the OEM 5mm setup. Also interested in seeing 5mm with 10 mm in the rear.
Old 01-10-2019, 02:15 PM
DOG ON
DOG ON's Avatar
Has anyone with a spacer setup noticed any kind of fuel economy (mpg) reduction after installing their spacers? If so, how significant?
Old 01-10-2019, 02:22 PM
LexVan
LexVan's Avatar
Received 5,387 Likes on 2,509 Posts
Spacers= easier to clean the calipers.
Old 01-10-2019, 02:24 PM
garfunkle
garfunkle's Avatar
Received 1,146 Likes on 629 Posts
on 50% of 991’s from the factory.
Old 01-10-2019, 02:26 PM
LexVan
LexVan's Avatar
Maybe 0.5%.
Old 01-10-2019, 02:35 PM
Joec500
Joec500's Avatar
I have been running 14mm rears and 12mm fronts without a problem for 3+ years 3 track days and 40k miles
Old 01-10-2019, 03:19 PM
NJ991
NJ991's Avatar
Just what I wanted to hear.
Old 01-10-2019, 04:47 PM
Joec500
Joec500's Avatar
As long as you don't go super wide >15-20mm and you remember to use high quality lug nuts of appropriate lengths there shouldn't be an issue. Well at least I have yet to have one with the level of driving I do, which to be fair is not that crazy. Even my track events are probably only pushing the car 8/10's at the most. I am by no means a pro racer.
Old 01-10-2019, 05:37 PM
adcampo
adcampo's Avatar
I know there is tons of threads on this, but is there an ideal spacer size for an C2S? Or is it just personal preference? I've read everything from the OEM 5mm all around to staggered 12mm F and 18mm R.
Old 01-10-2019, 06:55 PM
NJ991
NJ991's Avatar
I a
NJ991
NJ991's Avatar
I agree and have felt this way about getting proper hardware. I think Ill have this come this summer.
Old 01-10-2019, 10:15 PM
StormRune
StormRune's Avatar
The HRE's on my prior 991 C4S were sized with what was effectively a 12mm front and 13mm rear offset (partially from a ½" wider wheel and partially from a more aggressive offset). I thought the offsets were perfect. Here's a few angles of those. There were no problems with rubbing despite the front offsets being higher than you normally see.
Old 01-10-2019, 10:32 PM
NJ991
NJ991's Avatar
Very nice. 12mm up front looks perfect can, the back could do 15mm as well. Very nice HRE setup, classy.
Old 01-10-2019, 10:56 PM
Joec500
Joec500's Avatar
mine with 12mm on the front and 14mm on the rear. Remember the sporttechno are .5" wider than other standard wheels on the narrow body cars.
Old 01-10-2019, 11:13 PM
NJ991
NJ991's Avatar
Very nice.
Quick Reply: Question about Spacers
