Oil change reset / OBD tool or Durametric
Old 01-07-2019, 12:59 PM
fastdiablo
fastdiablo's Avatar
Default Oil change reset / OBD tool or Durametric
I just did an oil change in my 16 GTS. What are folks using to reset the oil change notice on the computer? Looks like the Icarsoft POR II is the way to go, but any other feedback or suggestions welcome before I buy one. Also, if you're selling one or something similar, DM me.
Cheers!
Old 01-07-2019, 01:05 PM
Guards_Red_991
Guards_Red_991's Avatar
I've had the POR II since I got my 997 and love it. I haven't found a thing I can't do with it.
Old 01-07-2019, 01:23 PM
GR997S
GR997S's Avatar
What model? Hopefully I can find one for my 997, 2018 Targa GTS and Cayenne GTS
Old 01-07-2019, 01:24 PM
JCtx
JCtx's Avatar
So you can actually reset the annoying oil warning with something other than Durametric? That's awesome news. Any links to the correct 'POR II' tool to buy, please? And is there a special software you need to buy, or can you just erase the stupid warnings right off the bat? Oh, for a 2015 Carrera S. Many thanks.
Old 01-07-2019, 01:25 PM
ipse dixit
ipse dixit's Avatar
Received 10,729 Likes on 4,762 Posts
I don’t believe the Durametric works to reset codes for the 991 generation. Need the PIWIS tool from Porsche.
Old 01-07-2019, 01:31 PM
Forrester
4th Gear
Forrester's Avatar
POR II works fine for my 2014 991.1
Old 01-07-2019, 03:38 PM
fastdiablo
fastdiablo's Avatar
Yes, just google "POR II Icarsoft porsche" it resets the oil change notice and other maintenance notices
i think it covers most porsche cars going back to 997 generation as well as Cayenne.
Old 01-07-2019, 04:55 PM
keithgreer
keithgreer's Avatar
This one. I got it and it works great.
Amazon Amazon
Old 01-07-2019, 06:11 PM
BusDriverBob
BusDriverBob's Avatar
Just reset mine yesterday with a POR II. Worked great, took less than 5 minutes on my 2014 C4S. If you get one you may want to make sure it is up to date with it's firmware before using it.
Old 01-07-2019, 06:54 PM
mreloc
mreloc's Avatar
I've had one of these for a couple years that I bought when I had my 997. I've been thinking about checking for a firmware update, but I've read that the updates can be problematic. Anyone have any first-hand experience?
Old 01-07-2019, 10:44 PM
bkrantz
bkrantz's Avatar
Originally Posted by keithgreer
This one. I got it and it works great. https://www.amazon.com/iCarsoft-Pors...arsoft+porsche
Works for me (2017).
Old 01-07-2019, 11:58 PM
mgordon18
mgordon18's Avatar
Worked very easily for me, including doing the initial software update as recommended when I unboxed it.
Old 01-08-2019, 01:40 AM
Cyberbug
Cyberbug's Avatar
I believe there is a newer version which allows or battery reprogramming as well por v2.0
Old 01-08-2019, 08:54 AM
Chris - 97C2
Chris - 97C2's Avatar
I was actually looking at both the POR II and V2.0 last night and trying to find the difference. Priced exactly the same. I seem to recall someone saying the II did battery reset as well, but not certain.
Does anyone here use the V2.0 with a 991.2? Seemed like everyone said they had the II.
Old 01-08-2019, 12:55 PM
Cyberbug
Cyberbug's Avatar
There are 3 actually P700 v2.0, POR v2.0 and POR II
POR II does not have BMS function, but I don’t see any difference between P700 and POR v2.0
i called the company several times but got routed to china every time.
i have sent an email hopefully will get a response.
Quick Reply: Oil change reset / OBD tool or Durametric
