2018 Carrera T, 991.2 2nd coolant leak
4th Gear
Does anyone know if this is a drain point for coolant? I'm concerned over another leak but was thinking its a drain plug and maybe not tight enough or bad washer? I'm on minimum after coolant check. Just had water pump replaced as well as other hoses 2 weeks ago. The replaced parts areas all dry
2018 carrera T 11000 miles
all else dry, except this
