Why I think PCCB is worth the upgrade on a 911T
Skip.
I would put that money into the wheel and tire budget.
I wouldn't be concerned myself since I only autocross and avoid real high-speed track use, but it was an interesting problem to see. I could certainly use less dust as the dusting on my current brakes against my gloss black wheels is the only thing that annoys me about my current car. I would certainly be more open to PCCBs after this.
I have no hard evidence of this but I recall reading somewhere around here ... there is no weight difference between the BASE brakes (standard on the T) and the PCCBs. I believe they weigh the same or very close to each other. So the real difference is perhaps no brake dust, greater stopping power, etc ... but not sure weight is an advantage? On the other hand, the S brakes (RED) are heavier.
Any one know for sure if this is true or not? FWIW I didn't spec them on my T as I couldn't rationalize spending nearly 10% of the cost of the car on brakes alone.
PCCB 's will return some % on resell but even if they did not they are worth it for dust alone. I regret not having them on my Macan but bought it off the dealer lot. Never buy another Porsche without them. Time is worth something and 45 minutes to clean steel is not worth it.
On the subject of PCCB's and track, I was shopping for a CPO two or three years ago and a potential car had just been in-processed at the dealer. However, the sales person I had come to know through a prior purchase gave me a warning Apparently the car had been tracked heavily during its 13k mile life since they were going to have to replace the PCCBs. They were already beyond CPO'able specs! However, I understand the newer PCCBs are much better with track life, but it would still give me pause IF that was my intended use since my pockets aren't quite that deep.
The new "white" Porsche’s Surface Coated Brakes (PSCB), which will apparently be an option on the upcoming 992, are an interesting development, though. Lasts 30 percent longer than steel, reduced brake dust, and cheaper than PCCBs.
https://www.caranddriver.com/news/in...-coated-brakes
I do autocross and they don't worry me. But for exactly the reasons you mentioned, I won't do DEs with PCCBs. I would rather have cheaper steels to replace. For day to day driving, love the feel, the looks, and the lack of brake dust.
Hopefully after PSCB launch PCCB after market price will drop...
I have to say I do not have that issue and I have over 10k on mine. I absolutely love the "no brake dust" aspect of the PCCB's and find them unbelievable in performance after having several Pcars with normal steel brakes. I would do it again. .
The problem that I realised recently is that although when you spec a new car PCCB cost is around 10K USD if you take a decision to install afterwards OEM Porsche PCCBs you need at least double price.
