Center lock wheels
Center lock wheels
I am now the happy owner of a 2018 GTS. My old car did not have center lock wheels and my new baby does. I am looking for a wrench to get the wheels on and off and torqued. Also does any one have a set of wheels for sale and can I ask for any pointers on these wheels. Thanks everyone for your help.
I use Precision Instruments C4D600F wrench. It works fine. I also am using Irwin (or any other brand) quick one-handed grip with long bar for pressing the brake pedal while working on front wheels. I also suggest to use a centerlock wheel guide tool to prevent scuffs.
Also, this is pretty much the bible on how to remove and replace Porsche center lock wheels
Make sure you use a wheel cleaner that is pretty gentle. I'm sure others can recommend different brands. The center lock nuts tend to discolor with harsh cleaners. I used Sonax and now have lovely mid-gray center lock nuts.
Received 2,010 Likes
Sub'd
Thx
Thx
a bit too late, but I find P21s works great and doesn’t discolour the locks.
Rocky Mountain High
My contribution to this thread:
https://rennlist.com/forums/991-turb...oto-heavy.html
Once you get used to it, you’ll find wheel changes to be quite easy.
When washing wheels, put a sandwich baggie secured with a rubber band over the nut to prevent wheel cleaner from discoloring it.
Rocky Mountain High
I use soap and water on my wheels, and I have no problems with the centerlock nuts discoloring.
I believe that I saw something here on Rennlist about using olive oil to restore discolored centerlock nuts.
Pain in the *** to keep clean. But once clean they look great.
Brilliant - thanks! I'm going to start doing that. Been looking for a way to keep the chemicals off the centerlock nut. Mine are definitely starting to grey.
only if you get lucky, and the chances are about the same was winning the lottery
