Bridgestone Potenza RE980AS
Old 11-12-2018, 05:41 PM
  #46
Thinc2
Thinc2's Avatar
Does anyone have pics of these tires mounted on the standard 11.5 inch wheels on the 991.2 C2/C4?
Old 11-15-2018, 01:31 PM
  #47
Benedict14
Benedict14's Avatar
I’d like to see this as well. I believe my center locks (991.1 GTS) are 11.5 Inches and I’m curious as to how the Potenzas would look.
Old 11-15-2018, 01:35 PM
  #48
Benedict14
Benedict14's Avatar
Originally Posted by Niez66
Based on the appearance of MY sidewalls with these tires on 11" wide rims, I would NOT put these tires on a 11.5" or a 12" rims.
They will appear stretched and expose the lip of the rim.
I'm drawing this conclusion after seeing these mounted on the pictures above, which were 12" rims on a GTS. They appear stretched and expose the side of the rim.
Niez,
Could you post some photos of the Bridgestones on your car please ? Throw us a frickin bone here
Old 11-15-2018, 02:54 PM
  #49
AlBinVA
AlBinVA's Avatar
Just back from running errands on a rainy cold day (41F) and found acorns around every corner. These Bridgestones just might be the answer for a DD in RVA.
I am a bit confused with the comments in this thread regarding wheel width and tire fitment. I have a 17 C2S. Is the consensus that these tires (305) will not fit the wheels???
Old 11-15-2018, 05:07 PM
  #50
Thinc2
Thinc2's Avatar
Originally Posted by AlBinVA
... I have a 17 C2S. Is the consensus that these tires (305) will not fit the wheels???
I think it's too early to make that conclusion based on the info in this thread. WE know two things so far:
1) It doesn't look great on 12 inch rims. However I don't know if this is a safety issue or just an aesthetics...
2) We known that one user has mounted them to 11 inch rims and doesn't recommend them on rims larger than that.
We haven't seen what they look like on 11.5 inch rims, so I think it's too early to draw any conclusions.
Old 11-15-2018, 05:10 PM
  #51
Niez66
Niez66's Avatar
My point on the comment regarding 11.5 rim was meant to say they will look a little stretched, but honestly they probably would perform just fine.
Old 11-15-2018, 05:16 PM
  #52
CaymanSinAR
CaymanSinAR's Avatar
I should get mine next week, but I'm not going to put them on my factory wheels. Wanted more weather flexibility. Having them mounted on O.Z. Leggera HLTs in 20x8.5 and 20x11.
I would have preferred to get a second set of factory wheels but not enough people are selling their 991.2 factory wheels yet.
Old 11-15-2018, 11:21 PM
  #53
Benedict14
Benedict14's Avatar
Photos of them on your rim ? Por favor
Old 11-16-2018, 09:28 AM
  #54
Rennolazine
Rennolazine's Avatar
Dont mess with Benedict.... give him the goods
Old 11-16-2018, 03:21 PM
  #55
Benedict14
Benedict14's Avatar
Old 11-17-2018, 04:35 PM
  #56
Benedict14
Benedict14's Avatar
Originally Posted by PorscheFrank
So I had the Bridgestone mounted on the stock GT3 wheels. Even though the Bridgestone are 305 like the sport cup 2s they don't fill the wheel like the Michelin's did. It's not terrible but not ideal either. To be honest it doesn't look that much better than the pics of those people who mounted 295 sottozeros on the 12 inch wheel.
I figured out why the Potenza AS doesn’t fit a 12” rim (your car, and any 991.2 with centerlocks.). They weren’t designed for it - The measured rim* for the rear tire is 11” and the rim range is 10.5” - 11.5”. So they’ll fit a rear that is within that range. Not 12”. Same deal with the fronts. These tires will fit an 11” rear (any wide body 991.1 without centerlocks) and they’re advertised to fit (rim range) any ceterlock 991.1 and a non centerlock 991.2.
I now know more about wheels than I wanted to. I’ve attached the web page below for reference to rim range etc.
* The measuring rim width is the industry standardized rim width upon which the tire must be mounted in order to confirm it meets its dimensional targets.
https://tiresize.com/tires/Bridgesto...-305-30R20.htm
Old 11-17-2018, 07:32 PM
  #57
Thinc2
Thinc2's Avatar
Thank you for researching this.
Old 11-18-2018, 02:21 PM
  #58
WhipE350
WhipE350's Avatar
Thank you. The question I have is the contact patch or (width) on the is P-Zero is 12.3". I'll keep searching but would like to know what it is on the RE980AS, I'm guessing it should be pretty close. My buddy and I both have 2017 S's and are looking at these.
Old 11-18-2018, 03:05 PM
  #59
Niez66
Niez66's Avatar
Default Pics on 11” width rim
evilfij (10-13-2019)
Old 11-18-2018, 03:57 PM
  #60
flgfish
flgfish's Avatar
Looks good. Thank you!
Quick Reply: Bridgestone Potenza RE980AS
