Bridgestone Potenza RE980AS
Old 10-22-2018, 11:12 PM
Niez66
Niez66's Avatar
Default Very pleased with the tires
I could not be happier with these tires, great value. The reviews about tire noise are over blown, coming off P- Zero’s which were worn, these tires are much quieter. Love the ride too, very smooth through the subdivision driving over the expansion joints.
The tread depth is significant, if you’re on the fence - don’t be. These tires will be on a ton of 991’s very soon.
Old 10-22-2018, 11:58 PM
evilfij
SJW, a Carin' kinda guy
evilfij's Avatar
Thanks for the review.
Old 10-23-2018, 01:28 AM
Papa Fittig
Papa Fittig's Avatar
Nothing wrong with Bridgestone. I've had them on all my cars except the current 911 since it is still on P0s. Many like Michelin better, but I like Bridgestone equally well.
For some of us who follow F1 long enough it is clear that performance-wise #1 is Bridgestone, #2 Pirelli with beloved Michelin being #3.
Once P0s are done in 7-8K I will take a look at Michelin and Bridgestone..
Old 10-23-2018, 10:58 AM
911boy
911boy's Avatar
Originally Posted by The Fat Kid
Are you planning on running all-season tires year round, or just during the winter?
If the latter: Winter tires will outperform all-seasons tire on cold, dry pavement due to rubber compounds. Winter-tire rubber is specifically designed for cold temps whereas all-season rubber must be able to handle all temperatures.
I run PA4s in the winter and they are great.
+1. Surprised anyone runs All seasons all year on a 911.
Old 10-24-2018, 10:50 AM
mberenson
6th Gear
mberenson's Avatar
I live in Northern New Jersey. I recently purchased the RE980AS as replacements for the Pirelli PZero. First impression is the ride is a little harsher going over bumps etc. as the sidewalls appear to be stiffer than the Pirellis. I also noticed that rocks still tend to be kicked up but not quite as bad as the Pirelli. That was one of the main reasons for switching to AS plus not having to rotate to winters. Overall, I do like the ride and feel of these tires and would recommend. I have a 911.1 C4S.
Old 10-24-2018, 12:12 PM
Thinc2
Thinc2's Avatar
I',m thinking of getting these to run year round in Seattle. For 4 months or so we have lots of mornings in the 30's (but rarely under freezing), and in the 40's - 50's in the afternoon on the way home. Lots of rain and wet roads.
Seems like a good solution for this climate - yes?
Old 10-24-2018, 07:59 PM
Niez66
Niez66's Avatar
Just an idea, but try playing with air pressure. I’m running cold 36f and 38r, made the bumps much smoother.
0luke1 (11-23-2019)
Old 10-25-2018, 11:49 AM
mberenson
6th Gear
mberenson's Avatar
Thanks. I will try.
Old 10-30-2018, 02:38 PM
P911T
P911T's Avatar
I just picked up a CPO 2014 911 Turbo S yesterday with brand new Pilot Sport Cup 2 tires fitted. Should I really expect dangerous driving when the temperature drops under 32?
scr1244 (12-08-2019)
Old 10-30-2018, 04:28 PM
StormRune
StormRune's Avatar
Well before that, even in the 40s they will be getting quite slippery, especially with the torque of a Turbo S. You can actually damage the tire in subfreezing temps.
Check out this recent thread about how P-Zeros do in the colder weather and then imagine these being worse since they are designed to withstand high track tire temperatures: https://rennlist.com/forums/991/1108...der-temps.html
0luke1 (11-23-2019)
Old 10-31-2018, 08:59 AM
P911T
P911T's Avatar
Cheers, I just ordered the RE980AS's from Tire Rack. Will report back in a couple of weeks once fitted.
Old 10-31-2018, 01:23 PM
Valvefloat991
Valvefloat991's Avatar
How does the sound level compare between the two tires? I know this is difficult to judge as worn tires with thin tread are always louder than new ones.
Old 10-31-2018, 07:02 PM
911mhawk
911mhawk's Avatar
Yes, should be.
I've had AS/3's and DWS and they are significantly better on our cold wet roads.
May try a set too. I've also been fine here for years on cars with summer tires and even NT-01's in the cold, you just have to remember what you're on.
Old 11-05-2018, 08:25 PM
francisluu
francisluu's Avatar
Originally Posted by Niez66
will give a review on them after the weekend drive.
Do you have a photo of these mounted on the car? I'm curious how the sidewalls look, if they look slightly stretched or not. What width wheels are you running by the way?
Old 11-06-2018, 01:23 AM
flgfish
flgfish's Avatar
245 / 305. You can read it on the stickers if you view the picture at full size.
Quick Reply: Bridgestone Potenza RE980AS
