Dealer left a screw on the engine cover after service
Mech33 impressive!!
This is why I am a member here....Awesome members looking out for each other.
That is the retaining clip that holds the satellite radio antenna in from the underside (it threads into the satellite radio antenna housing from below, and that plastic clip housing is what pushes against the body as kind of a large "washer").
Looks upside those openings in your rear deck lid under where the satellite radio antenna is and make sure it's not missing this part (there should be a rounded rectangular hole directly underneath the antenna housing). You basically found it in the exact spot where you'd expect it to land if it had fallen out...
If it did fall out, you may want to dig through your garbage as you can only get that part with an entire antenna assembly for ~$110...
https://dl.dropbox.com/s/8tvt9wxcstt...o_antenna.jpg?
[img]https://dl.dropbox.com/s/8tvt9wxcsttwqa2/sat_radio_antenna.jpg?
So did you remove or replace your satellite antenna hump?
No problem, happy to help!
Yes, I had the pleasure of replacing my satellite radio wart on my GT3... Porsche decided to deliver it with a black wart despite the car being green, so I bought a new one, had it painted to match, and swapped it in.
Hey JJPM - so was that part from your car in the end after all?? Curious how this worked out in the end.
Thanks again Mech33
@ Mech33, thanks for that info...so, my SAT radio died in my 2018 Targa GTS...they replaced the antenna...now there is a gap (that I don't remember) between the plastic 'hump' and the glass...will tightening that screw close that gap down a bit? I know there is a gasket that seats on the glass...
The "hump" may be reversed. On my coupe, the sloping surface faces forward. The hump does have gap all around of equal size and I am able to get a fingernail between it and the surface underneath.
