Most Aggressive AIR Foiler for 991
I bought the awe https://www.awe-tuning.com/awe-tuning-porsche-foiler-wind-diffuser
Great fit and finish but I always drive with windows down. Is there another that block more wind?
Looks like the blackmill is more aggressive. I'll put them on and compare to the other ones so others can make an informed decision.
http://www.blackmillperformance.com
I would have gone with the blackmill product simply because the fit, finish and install appeared better than the AWE counterpart. However, on the chance the double sided tape fails at speed, I don't want a metal projectile scraping down the side of my car and into whoever is behind me. I know much bigger things are held on with tape, it just made me uncomfortable so I installed the AWE unit, which I wish worked to foil the air just a bit better.
If you're going blackmill you might as well stick a pair of dive planes on each side of the car to complete the look. I will say this though about that tape they are using: no way are those coming off!
On my 981 I am not sure the AWE product really made that much of a difference. I have the parts ready to install on my T but I am going to hold off to see how things go.
Based on discussions on here since the 991 appeared in spring 2012, they all work. I made an easily removable one from scrap plastic and it worked perfectly, even with only one side installed. It doesn't have to displace much air to work.
