Changing clutch side fluid
I hope I can make myself clear. I track my 2015 C2S and am fastidious about maintenance. It was recommended that I change the clutch fluid in the trans axle. I was told to use Mobil 1 75w-90 gear oil.. When I pull off the inspection panels what should I be looking for? Thank you, this group is the greatest.
Received 5,388 Likes
Your clutch fluid is a shared system with you brake fluid. FYI.
Yes, your manual gear lube is a full synthetic 75W90. Buy the Porsche stuff. You need about 3 liters. Don't use just any ol' Mobil product. The OE supplier may even be Shell. Not sure.
Originally Posted by Captscrub
I am sorry. I did not make myself clear. My car has a PDK. I believe I was recommended to change the gear oil in the 'differential'.
