Black inserts on Carrera T steering wheel?
Old 09-27-2018, 12:33 PM
  #31
Cyberbug
Cyberbug's Avatar
I looked at suncoast and even under GTS. I don’t see any exposed screw/bolt black inserts for multifunction oe otherwise for GT wheel. May have the dealer find out and order a set from the GTS.
Old 09-27-2018, 02:43 PM
  #32
racemor
racemor's Avatar
Originally Posted by Cyberbug
any way to share the worksop manual or pics of this work? I would be very interested. Thanks in advance
a source for the workshop manual would also be appreciated.
Not a workshop manual, but a good DIY post:
https://rennlist.com/forums/991/1093...stall-diy.html
Old 09-27-2018, 04:16 PM
  #33
Cyberbug
Cyberbug's Avatar
Thanks, I also think the multifunction inserts with external bolts are not available in black. Only in silver
so I will be stuck with silver ones
Old 09-27-2018, 04:21 PM
  #34
Cyberbug
Cyberbug's Avatar
I take that back, this is easily doable.
the silver have exposed black screws but the black don’t
Old 09-27-2018, 09:48 PM
  #35
Cyberbug
Cyberbug's Avatar
Found this picture on the forum. After you remove ther steering wheel you would need to remove the three screws in the back. That will remove the lower trum and then you have access to remove the front large trim piece giving you access to remove those pieces.
Old 01-12-2019, 03:28 PM
  #36
Bob Z.
Bob Z.'s Avatar
Received 3,364 Likes on 2,307 Posts
Does someone have the link to the Black inserts for the 991.2 GTS Sport Steering wheel, non-mulit-function? I am thinking about sending my wheel out for some custom work and have them swap them out for the silver ones.
Old 01-12-2019, 04:04 PM
  #37
Cyberbug
Cyberbug's Avatar
Just ordered from Suncoast parts
https://www.suncoastparts.com/product/SKU718SWT.html
https://www.suncoastparts.com/product/SKU718LSW.html
what are you having done, I am also planning on having mine redone
Old 01-12-2019, 04:06 PM
  #38
Bob Z.
Bob Z.'s Avatar
Thanks, and I am thinking about having Craft Customs redo my steering wheel with a dial stripe at 12 o'clock and while at it I would send them the Black inserts to install.
Old 01-12-2019, 04:39 PM
  #39
Rennolazine
Rennolazine's Avatar
Craft customs did my macan wheel. Great work!!!! Its does make the wheel thicker if you have heating (they have to wrap over it) though so make sure they assemble it otherwise the trim wont clamp on tight
Old 01-12-2019, 05:48 PM
  #40
Cyberbug
Cyberbug's Avatar
I got a quote from someone I have used in the past of $580. Requesting craftcustom for a quote as well
Old 01-12-2019, 06:07 PM
  #41
Rennolazine
Craft custom is 500 ballpark but u ship the wheel. Also ask about their perforated napa leather its awesome
Old 01-12-2019, 06:28 PM
  #42
ryandarr1979
ryandarr1979's Avatar
I replaced the silver trim multifunction switches with black from suncoast. Disconnect the battery after opening the door. Two holes bottom of steering wheel with a small flathead to release the airbag module. Use same small flathead to unplug the yellow and orange airbag plugs. T55 Torx drive and a ratchet to remove the bolt and wheel. Small torx drive to remove rear wheel cover, and then a little more manual labor. Took about an hour start to finish. I’m mildly mechanically-inclined.
Old 01-12-2019, 08:22 PM
  #43
Bob Z.
Bob Z.'s Avatar
You make it sound so easy! I MIGHT be able to do it, with lots of pictures.
Old 01-12-2019, 08:35 PM
  #44
Rennolazine
Ill make a video in spring
Old 01-12-2019, 08:57 PM
  #45
Bob Z.
Bob Z.'s Avatar
Cool babies, looking forward to it.
Quick Reply: Black inserts on Carrera T steering wheel?
