PCCB and "increased comfort"
Originally Posted by smmmurf
My GT4 has PCCB's and my friend's GT4 has standard brakes. I drove them back to back and noticed that the car with PCCB's rode a bit better. It seemed ilke the suspension recovered from bumps quicker. Both cars had Michelin Pilot Sport Cup 2 tires from the factory.
I have since switched the factory wheels to 20" BBS FI-R wheels. Combined with the ceramic brakes, the car carries about 70 pounds less unsprung weight than a standard GT4 with 20" OEM wheels and steel brakes. It is still not a comfortable car with the sport buckets and firm suspension, but the agility is amazing and the ride is better than acceptable. I would change the brakes from my 991 C2S to PCCB's if presented with the opportunity.
Those wheels look fantastic by the way.
This guy does
https://bringatrailer.com/listing/1976-porsche-911-10/
"This results in better roadholding and increased comfort, particularly on uneven roads, as well as greater agility and a further improvement in handling."
Does anyone take their 911 off-roading? Low ground clearance, not to mention limited angle of approach and departure would seem to argue against going off-road with a 911. Maybe applicable to a Cayenne, but I don't think so with the 911.
Former Vendor
We've weighed the difference between a set of OEM iron and ceramics and its roughly 45lbs, and that is unsprung/rotational mass. That is a noticeable difference on and off the track, and is a major factor in why we are converting iron rotor cars to our refurbishable ST ceramics.
Former Vendor
That was 380mm front and rear rotors off a GT4/GT3 versus 410mm/400mm ST ceramics. We don't have ST ceramics for S or Base models, at least not yet so we've never weighed the difference on those.
I have PDCC which is supposed to increase comfort. I have PCCB which apparently also increases comfort. If it weren't for SPASM I bet it would ride just like a Lincoln town car!
Seriously though, on bumpy roads, it's not what I'd call "comfortable" - on reasonably smooth highways, it's fine (yet can be noisy). Any improvement in "comfort" from these options is marginal. Don't set your comfort expectations too high - you feel every bump and that's the way it's supposed to be.
Former Vendor
Why thank you, I appreciate that! You should join the fun and get a set ; )
That all depends on the use of the car, but we have been using three different versions of Pagid pads with great success to accommodate various levels of driving and comfort. It is quite the upgrade, you'd thoroughly enjoy it as everyone has that's running them
In case it helps you and/or others, my car is a 991.1 turbo (non-S) with iron rotors, 5 bolt wheels.
Former Vendor
Three versions of Pagids? My current contemplation for pads with iron rotors would be Porterfield R4-S or Ferodo DS2500. Which Pagids would you suggest with your rotors that match up (or approximate) these?
