Is this a Cracked Windshield?
Old 07-07-2018, 06:54 PM
kornface13
kornface13's Avatar
Default Is this a Cracked Windshield?
I just had my cracked windshield replaced about 40 miles ago, and I'm seeing something that appears to be another crack. It looks very similar to the other lines in the windshield, but it goes from the edge of the drivers side, about halfway across the drivers half of the windshield near the bottom. It's pretty straight, but not perfectly straight. Passenger side doesn't have the same thing. I don't recall seeing this on the old windshield or when I picked it up. I took a video. Video starts showing the normal lines in the windshield, which I think are the antenna, then goes to show the possible crack I'm referring to.
My finger is pointing to where the line stops. Can anyone confirm if this is normal on a 991 windshield?
Old 07-07-2018, 06:55 PM
Sidvicious7
Sidvicious7's Avatar
It’s your antenna. My windshield has the same setup.
Old 07-07-2018, 06:59 PM
alainpp
alainpp's Avatar
It looks like the heat circuit/cable for the windshield.
Old 07-07-2018, 07:08 PM
WarEagle13
WarEagle13's Avatar
It's your antenna.
Old 07-08-2018, 12:40 PM
kornface13
kornface13's Avatar
Thanks everyone. I thought the antenna was in the middle of the windshield.
Old 07-09-2018, 01:32 PM
Alec Syme
Alec Syme's Avatar
The antenna is in the middle of the windshield. I'm not sure what you're pointing to there. I don't have anything besides my antenna (in the middle) on my car.
alec
Old 07-09-2018, 02:39 PM
kornface13
kornface13's Avatar
I'm pointing to the end of the "crack". It goes from the drivers side to where my finger is. If you look at the youtube link you can see the crack as I pan across the windshield. But I can't really capture it in a photo.
Old 07-09-2018, 03:08 PM
Scottykenneth
Scottykenneth's Avatar
I thought the same on mine. I have the same. Ur good
Old 07-09-2018, 04:53 PM
kornface13
kornface13's Avatar
Just visited the local dealer. Not all cars have this line. Some do, some don't. Saw a GT4 with it, and a Carrera S without it. I have a Carrera S. Very odd. I've asked them to pass the question on to Porsche.... We'll see if I ever hear back.
Old 07-09-2018, 08:10 PM
Gordon Shumway
Gordon Shumway's Avatar
It's a heat strip, or an antenna, not sure which. However, I'm sure it is not a crack. I have the exact same thing on my '18 GTS. I can't think of an option I have that would make it special.
Old 07-09-2018, 10:04 PM
DBH
DBH's Avatar
Just looked at the windshield on my '18 GTS - nothing there.
Old 07-10-2018, 02:49 PM
gellie
gellie's Avatar
Just checked my 17 C2 S. Nothing there. Are you sure they replaced the windshield with OEM?
Old 07-10-2018, 03:28 PM
arter
arter's Avatar
My 18 GTS has the antenna vertically in the middle, and then goes to the passenger side and down via the top of the winshield. electrical connections are on the left side ( passenger side) about mid height on the window.
If your am/fm works, then all is good. It is an antenna wire
Old 07-10-2018, 04:04 PM
gellie
gellie's Avatar
Um. I guess I need to see if my AM/FM is working. Its been years since I've listened.
Old 07-10-2018, 04:07 PM
Hurricane
Hurricane's Avatar
Same here (also on an '18 911GTS). Not like the OP's description.
Quick Reply: Is this a Cracked Windshield?
